90
OxygenOS Open Beta 8 for the OnePlus 7T Pro and 7T
  1. zer0se7en
    Ice Cream Sandwich Sep 23, 2020
    zer0se7en , via OnePlus 7T , Sep 23, 2020 :
    Never had any major issues with all the betas. The only small issue I had was on beta 3 and 4 when rotation was not working. That's about it.
    Stuff I do before installing an update:
    - clear cache from Recovery mode
    - clear junk using Clear Master
    - make sure to Greenify most apps that run in the background (also tweaked some on the settings via ADB commands)
    So far so good. Been doing this since OnePlus One, X, 5T and now on 7T. [e]270c[/e]️[e]1f601[/e]. Actually since December 2019 on my 7T. That's when I bought it.
  2. zer0se7en
  3. zer0se7en
  4. Jake matt
    Eclair Sep 23, 2020
  5. zer0se7en
  6. Jake matt
    Eclair Sep 23, 2020
    Jake matt , via OnePlus 7T , Sep 23, 2020 :
    Hmm alright, I'm on stable build and it is still not come in that. Btw how is open beta? Is it stable enough to use evrdayy?
  7. zer0se7en
    zer0se7en , via OnePlus Community App , Sep 23, 2020 :
    Yes. Haven't been on Stsble build since Open Beta 1.
    But I heard banking apps do not run well on betas. Haven't tried though, coz I do not do banking on my phones.
  8. Jake matt
    Eclair Sep 23, 2020
    Hmm wat bout everything else..the battery sot and all?
  9. PrinceVamshi
    Cupcake Sep 23, 2020
    kunu7458 likes this.
  10. zer0se7en
    As you can see on those screenshot I just posted, SoT got 8hrs+.I have no problems on battery. 7-8hrs on WiFi 5-6hrs on data. Still depends on what you always do on your device.
  11. zer0se7en
  12. PrinceVamshi
    PrinceVamshi , Sep 23, 2020 :
    and one more thing there notification issue Pop-up 😐
  13. Jake matt
    Eclair Sep 23, 2020
    Damn bro how u getting 8hrs sot and stuff. The peak I've touched is 6hrs with wifi
  14. zer0se7en
    Greenify
    Turn off connections that are not in use.
    - NFC
    - bluetooth
    - location services
    - Accounts Auto Sync Data
    Also check Battery optimization.
    On default they are all on Intelligent Control.
    Put some apps that you rarely use to Optimize.
  15. zer0se7en
  16. PrinceVamshi
    from yesterday onwards iam getting notification issue for some apps like whatsapp fb messages etc...
  17. Avdeshraghu0
    Gingerbread Sep 23, 2020
    Avdeshraghu0 , via OnePlus 7T , Sep 23, 2020 :
    Need an update to improve camera quality. If you compare it with OnePlus 7 pro or 8 it's camera did not give such quality photos even having same sensor. It was ok but after so many updates they disturbed its camera optimization codes for sure.
  18. zer0se7en
    And what OS version are you on?
  19. PrinceVamshi
  20. zer0se7en
