90
OxygenOS Open Beta 8 for the OnePlus 7T Pro and 7T
  1. emailtosivakumar
    Gingerbread Sep 18, 2020
  2. emailtosivakumar
    emailtosivakumar , via OnePlus 7T , Sep 18, 2020 :
    There is no FPS metre
    Cpu and GPU usage .
    If they give that that will be awesome.
    L1577420140745, ananyr and Lemillion like this.
  3. emailtosivakumar
  4. emailtosivakumar
  5. gauthamdurai
    Froyo Sep 18, 2020
    gauthamdurai , via OnePlus 7T , Sep 18, 2020 :
    Real update is fixing problems which most of the users are facing daily. . Like battery drain issue, camera focus issue or the one hand mode. . If you check the change logs, almost all the problems are useless which won't affect our daily driver. . Even if it is fixed, we actually don't know as we never or rarely use those features. .
  6. emailtosivakumar
  7. emailtosivakumar
  8. emailtosivakumar
  9. MD.Khan
    Froyo Sep 18, 2020
    MD.Khan , via OnePlus 7T , Sep 18, 2020 :
    U r right. But let them give some time [e]263a[/e]️
    emailtosivakumar likes this.
  10. balajiinkulu
    Cupcake Sep 18, 2020
  11. N1580388597241
    Froyo Sep 18, 2020
  12. J1585090666932 , via OnePlus 7T Pro , Sep 18, 2020 :
    Considering that's it's not available even in the OxygenOS 11 betas, looks like One Handed mode is not coming at all. Even though it was promised for my not cheap at all OnePlus 7T Pro almost an year ago. Then 3 months ago again.
    Luckily Android app developers picked up the task, and I am now using the amazing app "Quick Cursor" so I don't have to wait and rely on you adding this basic and promised functionality.
    The fact that you never came out to say that you are scraping (or releasing more than an year after promised) the One Hand mode, but just keep moving the goalposts leaves a very bad taste in my mouth however.
    afogel likes this.
  13. emailtosivakumar
    WEBSDCOOL likes this.
  14. Zheckan
    Froyo Sep 18, 2020
    Zheckan , via OnePlus 7T Pro , Sep 18, 2020 :
    Hello world, I have a problem. After updating to beta 7, the call gesture for Google assistant stopped working (from the edge of the screen). After updating to beta 8, the problem remained.
    Does anyone have a similar problem? There is a solution? Thanks :)
  15. WEBSDCOOL
  16. Prajjawal
    Prajjawal , via OnePlus 7T , Sep 18, 2020 :
    These minor changes are almost negligible, Plz work on better software for Android 11. The beta version of Oxygen OS 11 was looking like One UI. I understand that u guys are optimising the OS for one-hand use, but keep the same standard Oxygen OS. OnePlus makes good phones, but what makes it great is Oxygen OS. The day OnePlus mess up with the OS, it will be the fall of OnePlus. But, prepare for the best, hope for the worst🙂.
    ONEPLUS
    NEVER SETTLE.
    tanaye1013 likes this.
  17. emailtosivakumar
  18. emailtosivakumar likes this.
  19. emailtosivakumar
    Literally this beta has toooo many bugs.
    When I see the time it showed 1.45pm and after 2 min it showed 2.7pm .
    Swiping between apps is crashing.
    Battery is somewhat draining.
    Phone is heating .
    Ui feels faster but when I open something in slows.
    Fix the bugs faster..
    And if you can please don't give gryesh colour in notification bar in Android 11.
    Lemillion likes this.
