477
OxygenOS Open Beta 8 (Nougat) for OnePlus 3
Thread Status:
Not open for further replies.
  1. shriommanerker
    Froyo Dec 10, 2016
    shriommanerker , Dec 10, 2016 :
    i installed beta 7, then local upgrade to beta 8, went to recovery, wiped everywhing including internal storage for f2fs data partition.
    my phone is always on mobile data and my screen on time figures are usually around 1.4-2.5 hours after 12 hours on battery and my percentage is about 50% remaining when i get home(before leaving off to work i charge to 90% and never above that). and this is when im using Both 4g sims, Reliance JIO and Idea 4g, ofcourse since my jio is the primary the idea sim idles at UMTS connection, these figures are insane since earlier i used to reach home at 20-15% battery on the exact same usage.
    G_Aasim_Sarwar_FTZc likes this.
  2. danimartinez95
    Gingerbread Dec 10, 2016
    danimartinez95 , Dec 10, 2016 :
    It Okey every one should report the bugs. That La the work of be a beta tester. If someone already reported also they report to help the development. I don't know what happen with you
  3. Hsin Chang
    Cupcake Dec 10, 2016
    Hsin Chang , Dec 10, 2016 :
    Question: Will next open beta be OTA to our open beta 7 users? And when can we get a Nougat OTA update?
    Nil2010 likes this.
  4. Intruder71
    Lollipop Dec 10, 2016
    Intruder71 , Dec 10, 2016 :
    Not very helpful when you're reporting them I the wrong place is it.... This ain't the bug tracker
    otto2 likes this.
  5. ruhela786
    Ice Cream Sandwich Dec 10, 2016
    ruhela786 , Dec 10, 2016 :
    Go through the thread please, don't ask the same question which has been answered several times.
    otto2 likes this.
  6. fjvaz1995
    fjvaz1995 , Dec 10, 2016 :
    Most probably not, u will have to manually update to beta 8 then u will get beta 9 via OTA, the reason is f2fs file system supported on nougat.
    As far as official OTA for nougat should be there by the end of December.
  7. Daniman21
    Daniman21 , Dec 10, 2016 :
    Chill
  8. ghostofcain
    Marshmallow Dec 10, 2016
    ghostofcain , Dec 10, 2016 :
    This makes no sense,what does f2fs have to do with it? I can see if beta 8 only supports f2fs then anyone not using it already would possibly be unable to OTA update. What makes you think f2fs is going to be obligatory henceforth?
  9. ironass
    ironass , Dec 10, 2016 :
    Totally and utterly, my bad. I forgot that I had reverted to Open Beta 7, yesterday for testing purposes. DUH! Having said that, I did not experience any issues with TCW in the week that I was on Nougat.
    otto2 and ghostofcain like this.
  10. G_heshaibani_oqyI
  11. Haroon117
    Honeycomb Dec 10, 2016
    Haroon117 , Dec 10, 2016 :
    So I performed a factory reset from the phone's settings and then went straight into TWRP to wipe the Cache. I just rebooted and there were no changes, as if I didn't just factory reset. All of my apps and app data currently seem to be present. Should I wipe everything from TWRP? (Other than internal storage, and system)
  12. fjvaz1995
    He asked if the next CB will be via OTA, and since beta 8 wasn't so will be beta 9, the reason for beta 8 not being an OTA was a complete new OS and f2fs file system.(Since u had to format the internal storage for the same).
    There might be an alternative for the official update, but beta 9 wont be an OTA over beta 7.
  13. ghostofcain
    Sorry my bad confusing my betas, yes you are right OTA for beta 7 ain't happening.
    fjvaz1995 likes this.
  14. -cart3r-
    Eclair Dec 10, 2016
    -cart3r- , Dec 10, 2016 :
    Can not activate cellular data sim card, mobile internet settings are done in vain all is not running, the SIM card is Telekom
  15. alexferdean
    alexferdean , Dec 10, 2016 :
    Since I installed Nougat Beta, my car Parrot CK3100 cannot keep the Bluetooth connection. Previously it worked perfectly. Anyone else with this problem? I already did a factory reset in recovery.
  16. prasetyoh
    Froyo Dec 10, 2016
    prasetyoh , Dec 10, 2016 :
    Actually, my friend's iPhone 5 battery degrades pretty much after about 2-2,5 years of usage. The total capacity degrades to -+900mAh (from about 1440mAh designed total capacity) (there's an app to see that on iOS, never know on Android). After he replaced the battery, the app detect the new ones in full capacity, and the usage time of the phone was improved significantly.
    But since I bought a new phone (almost) once every year (sometimes 1,5 year), this degradation thing aren't bother me much. If the battery do degrades but you want to keep the phone, you can just replace it with the new battery, rather than having to recharge/discharge it on certain percent. Just my two cents -- each person has different priorities. ☺️
  17. ghostofcain
    But you are only using 40% of available capacity, even your friend with his horrific degradation, I'd have returned that phone as unfit for purpose sold, still had more available battery percentage than that after 2 years usage, crazy, crazy people.
  18. vn75insider
  19. vn75insider
    vn75insider , Dec 10, 2016 :
    Your problem 's all answered on the foregoing pages .It's as easy as your sipping of coffee. As for "lagging" that said for 1 million times. Please activate a developer options in which you will see and set ON some more things !
  20. tusharvan
    tusharvan , Dec 10, 2016 :
    Yes also while playing videos, the music doesn't play until I wait for a few seconds. Anyone with this issue?
