477
OxygenOS Open Beta 8 (Nougat) for OnePlus 3
Thread Status:
Not open for further replies.
  1. Scherpenseel
    KitKat Dec 13, 2016
    Scherpenseel , Dec 13, 2016 :
    Nah, Just ignoring it is more fun :).
    fjvaz1995 and Xgrind like this.
  2. Sun90
    Starting Point Expert Community Expert Dec 13, 2016
    Sun90 , Dec 13, 2016 :
    1) Not so in my case it stays with selected option.
    2)That's the nougat style for now, even on Nexus/Pixel device it's the same.
    3)It's the same even on Nexus/Pixel running Nougat
    4)It had been removed for now.
    5)It had been moves, u will find the same if u go to System settings>Apps and there hit the cog wheel and u can see the option there.
    6) Not the case with me, I can quit without issue.
    7) Use default theme and open the same,then u can revert back to dark theme
    so none of the above are bugs except no.7
    otto2 likes this.
  3. Sun90
    the only issue with the black theme is the Ascent colors are not properly distributed for now.
  4. Archies
    Ice Cream Sandwich Dec 13, 2016
    Archies , Dec 13, 2016 :
    Yes yes i like to cry it's healthy :p
    50960 likes this.
  5. red_argh
    Froyo Dec 13, 2016
    red_argh , Dec 13, 2016 :
    it would be great, if they have added the landscape view in Nougat launcher
  6. RAKESH J R
    Gingerbread Dec 13, 2016
    RAKESH J R , Dec 13, 2016 :
    No Matter what updates roll in or not - Please dont forget the InCallUI to be made full screen to display photo of the caller.:)
  7. SpazeApparel
    Cupcake Dec 13, 2016
  8. Sun90
    Not Much are in favor of it ,IMO it's not going to happen.
  9. UncleRen
  10. MarkLR
    Jelly Bean Dec 13, 2016
    MarkLR , Dec 13, 2016 :
    I'm starting to get impatient for a new one. The bugs are getting out of hand these days.
    1. Shelf is as always literally unusable as widgets either glitch out or get stuck after a day or so
    2. I have issues with WiFi, the setting to always use 2.4ghz bands reverts and causes instability with the connections. Maybe it's my shitty vodafone router which has crappy 5ghz stability but before if I set it to only use 2.4 it worked just fine, now I can't really tell if it's the setting that keeps reverting (I know it does revert explicitly sometimes) or what but my WiFi is ridiculously unstable.
    3. I had my proximity sensor get stuck and pocket mode was constantly enabled, a reboot fixed it
    4. I had my WiFi literally unusable for a while, a reboot fixed it as well
    5. For some reason every time I reboot the phone, my alarm which is set at 7AM rings no matter what, seriously wtf is up with this
    6. Battery saver kills whatever app is open at the time of enabling, sometimes I forget about it and then I have my currently used app killed
    7. Not sure wtf happened but I had my screen completely active while I was having a call, with my face I touched the screen and enabled the flashlight without realizing, then the whole systemui glitched out and I could not pull down the dropdown menu and my flashlight was stuck on, had to reboot the phone to make it work properly again
    8. I was taking long exposure photos in manual mode, I set the exposure to 30, set up my phone on a tripod, and started taking the photo, but then I changed my mind and canceled out using the back key, my camera got completely stuck on a black screen and there was nothing I could to to make it work again, tried everything but it displayed nothing but a black screen. A reboot fixed it.
    Other than that though, the system is stable and battery life is ok. BT connection quality has improved with my car too with N.
    Also they need to implement some way to make the phone automatically switch to silent (Do Not Disturb mode like on stock Android) at certain hours or at certain events. I'm seriously tired of either forgetting to set the phone to silent before falling asleep and then getting woken up in the middle of the night by retarded notifications, or having the same issue, not forgetting to set my phone to loud and not hearing notifications until I realize it.
    You may say it's my fault but all Android phones have had Do Not Disturb for ages and I can't get used to thid god damned manual switch. The only use I have for this switch is to set the phone to silent when I want to watch porn and I forgot my headphones, literally.
    Sahilkum likes this.
  11. 50960
    50960 , Dec 13, 2016 :
    Simply proved - you did not get it. Period.
    Sun90 likes this.
  12. Auristic
    KitKat Dec 13, 2016
    Auristic , Dec 13, 2016 :
    So please share with us all the nice features they've got and you haven't...
  13. Artur4Life
    Froyo Dec 13, 2016
  14. Sun90
    M
    May be some time tomorrow.
    If it's as per community build rollout timeline
    Stroky750 likes this.
  15. Scherpenseel
    KitKat Dec 13, 2016
  16. sapnikos
    Eclair Dec 13, 2016
  17. F_Cédric_Catonyme_mwQu
    F_Cédric_Catonyme_mwQu , Dec 13, 2016 :
    A build that works without bug ? A build that can be downloaded (why disabling download link ? If you want to use a buggy beta that's the problem of users...
    And biggest part : if you already have beta 8... You cannot even install the officiel release directly ! So you are stuck wit ha ******* beta build with no update for now ?! ?! ?!
    Is it enough for you ?
  18. Artur4Life
    Froyo Dec 13, 2016
  19. Auristic
    KitKat Dec 13, 2016
    Bye then: I reckon I won't be the only one to NOT miss you here! ;)
  20. M3ntoR
    M3ntoR , Dec 13, 2016 :
    ok so regarding point about missin battery precentage view....People it is available but it's hidden :)
    1. Slide down the notification bar.
    2. Long press on settings gearwheel
    3. You receive info that System UI calibrator is turned on now and to stay catious with it
    4. Go to settings, scroll all way down
    5. Open System UI calibrator
    6. Turn on Battery Precentage
    7 $$$$PROFIT$$$$
    You're welcome
    sachitsingh likes this.
