477
OxygenOS Open Beta 8 (Nougat) for OnePlus 3
Thread Status:
Not open for further replies.
  1. ddwong1984
    Cupcake Dec 1, 2016
  2. G_an_lee_DTvR
    Cupcake Dec 1, 2016
  3. Mrhohoha
    Eclair Dec 1, 2016
    Mrhohoha , Dec 1, 2016 :
    Having trouble updating/installing apps from the Play Store on mobile data. Cleared data etc. Fixes?
    Gaurav_jha likes this.
  4. EriX888
    Gingerbread Dec 1, 2016
    EriX888 , Dec 1, 2016 :
    Issue to raise!
    Did this nougat solve the most hated issue if all?
    So the camera software processing issue is common to every single oneplus 3, if u dont know already i will tell once again, i dont want this issue to be burried everytime.
    1) camera slow shutter speed in automode- making the picture blurred, i have no idea why but even the slightest hand movement, the hand or even face expression will appear distorted and blurred out in the album. (Dont believe me? Take a picture of ur moving hands even slow moving hands, u will see) this is absolutely unacceptable, i know there is manual mode but do u want to do that every single time when plus it resets back everytime? Or when u are out at the park taking pictures of ur family or pets but all the pictures are utter nonsense that cannot be accepted, auto mode is for immediate use, so make it be like that. This is a flagship killer, if others flagship like samsung and iphone has good image processing so should u, plus there is no excuses for this as the sensor is not a bad one either. (Correct me if im wrong, im all ears, unless u tell me there is no cure then fine, i will make sure this issue is known to everyone before they buy)
    2) again, when u take a picture of moving objects it will sometimes appear crisp at the moment, (then do this instantly,) go to album and look at the photo taken, it will change position after a few sec, like whattt!? Is this some dark sorcery or 'new features' of flagship killer? I dont want this
    So im not asking for super hard request here, camera is very very essential in daily life, what is the point of taking only still photos, sometimes even the stills have problems like blurring etc, fix ur phone, make oneplus great again
    And readers, If u have above problems, do ur part and copy paste this every where, even reviewers make this hidden issues, i want to make this issue settle once and for all, contrary to ur slogan. Thanks!
    From angryoneplus user
    tedulus likes this.
  5. aswinajraj
    Cupcake Dec 1, 2016
  6. Baibhav_Kumar
    Honeycomb Dec 1, 2016
    Archies likes this.
  7. rupeshbk
    rupeshbk , Dec 1, 2016 :
    Another open beta - Always Settle Should be the mantra :D - Looking at what happened with OP2 and the official MM we are looking at another 3 months..
  8. Archies
    Ice Cream Sandwich Dec 1, 2016
    Sahilkum likes this.
  9. G_Aasim_Sarwar_FTZc
    G_Aasim_Sarwar_FTZc , Dec 1, 2016 :
    Multi window works fine on on-screen nav bar.. Click on recent buttons.. Then long press on any app window and drag it towards top of the screen.. The app should now get 'tucked' on the upper half of the screen now.. Then click on another app and voila! Lemme know if it doesn't works..
  10. Pcsx2006
    Eclair Dec 1, 2016
    Pcsx2006 , Dec 1, 2016 :
    Many big developers already updated their apps with vulkan api support.
    Asphalt 8 use to take 30 seconds to load on official or CB even bets 7 now on beta 8 it takes 6,7 seconds and that's a huge difference, also game is much more smooth fps wise.
  11. G_Aasim_Sarwar_FTZc
    Scherpenseel, Archies and Sahilkum like this.
  12. dattaprasad.patil.88
    dattaprasad.patil.88 , Dec 1, 2016 :
    I cant see any gear icon in system updates. Just fyi my OP3 is not rooted.
    Thanks,
    DSP
  13. __saurav
    Froyo Dec 1, 2016
    otto2 and Sahilkum like this.
  14. nikhilsnigam
    Froyo Dec 1, 2016
    nikhilsnigam , Dec 1, 2016 :
    +1 for the camera issues
    Did you atleast see properly? both are there in sound and security settings.
    Sahilkum and EriX888 like this.
  15. Shivamnarang
    Eclair Dec 1, 2016
  16. G_Aasim_Sarwar_FTZc
    Are you on Open beta of marshmallow or official version? Coz open beta would have a cog wheel on top right of system update.. If you are on official version then you have to sideload it using adb
    dattaprasad.patil.88 likes this.
  17. Shivamnarang
    Eclair Dec 1, 2016
    Shivamnarang , Dec 1, 2016 :
    i tried id doesn't worked for me .... i think it was removed in open beta 7
  18. James Matthew Wells
    James Matthew Wells , Dec 1, 2016 :
    Flashed via local and then did complete wipe/ factory reset and set up as a new phone from scratch. Works AMAZINGLY.
  19. Pcsx2006
    Eclair Dec 1, 2016
    Working great on my device not only graphics are great also much more smooth and faster loading, nfs nl, asphalt 8, real racing 3 I checked all.
  20. Archies
