477
OxygenOS Open Beta 8 (Nougat) for OnePlus 3
Thread Status:
Not open for further replies.
  1. leleg
    Cupcake Dec 1, 2016
    leleg , Dec 1, 2016 :
    you are on official build.. i am on community build so i had the gear icon
  2. Retchey
    Gingerbread Dec 1, 2016
    Retchey , Dec 1, 2016 :
    Piece of piss, downloaded onto phone, copied into internal storage, went to local upgrades in systems update, and initiated upgrade, did it all on my morning tea break at work, all up it took about 15 minutes from rom to rom... So easy, thanks oneplus for making the process so easy....
  3. thiazhangwei
    Honeycomb Dec 1, 2016
    thiazhangwei , Dec 1, 2016 :
    I'm going to risk a limb and say that it's support for 3rd party applications as shortcuts on the lockscreen. You know, the one which you can swipe from the bottom left/right?
  4. F_Matas_Matufa_Janulis_z
    Cupcake Dec 1, 2016
  5. alwayswynne
  6. Nithinthodupunoo
    Froyo Dec 1, 2016
    Nithinthodupunoo , Dec 1, 2016 :
    Services?? i downloaded the app but how to get the services?
  7. brath23
    brath23 , Dec 1, 2016 :
    Well, I investigated this problem and the problem happens because I removed Oneplus Gallery.
    12-01 08:25:57.538 I/WindowManager( 1492): Destroying surface Surface(name=Starting com.oneplus.camera) called by com.android.server.wm.WindowStateAnimator.destroySurface:2043 com.android.server.wm.WindowStateAnimator.destroySurfaceLocked:905 com.android.server.wm.WindowState.destroyOrSaveSurface:2074 com.android.server.wm.AppWindowToken.destroySurfaces:407 com.android.server.wm.WindowStateAnimator.finishExit:566 com.android.server.wm.WindowStateAnimator.stepAnimationLocked:492 com.android.server.wm.WindowAnimator.updateWindowsLocked:303 com.android.server.wm.WindowAnimator.animateLocked:704
    12-01 08:25:57.538 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.539 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.540 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.541 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.542 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.546 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.548 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.550 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.551 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.552 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.554 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.555 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.557 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.558 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.559 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.562 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.563 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.564 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.565 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.566 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.567 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.568 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.569 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.570 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.571 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.572 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    12-01 08:25:57.573 E/ActivityThread(10794): Failed to find provider info for oneplus.gallery
    I removed always Oneplus Gallery in previous build and I didn't have this issue before.
    I tried reinstalling Oneplus Gallery from Google Play Store but it's still failing, I guess I have to push it so system
    For me it's a incovenience because Oneplus gallery is of no use for me. I'll learn to live with that
    Eshan_Anand likes this.
  8. kapilathi
    kapilathi , Dec 1, 2016 :
    Hmm.. But there is no option to configure it
  9. vn75insider
    Ice Cream Sandwich Dec 1, 2016
    vn75insider , Dec 1, 2016 :
    *#*#4636#*#*
  10. G_BMWKante_vKip
    Donut Dec 1, 2016
    G_BMWKante_vKip , Dec 1, 2016 :
    What is about WLAN bandwidth? Did you notice also the speed is only 433 mbit/s instead of 866 mbit/s?
  11. SMudassar121
    SMudassar121 , Dec 1, 2016 :
    I m gonna do after that. Letme know if factory reset changes ur file system or not !
  12. kapilathi
    Well, there is no option to select the lockscreen shortcuts
  13. sivabalan83
    Donut Dec 1, 2016
  14. sivabalan83
    Donut Dec 1, 2016
  15. Eshan_Anand
    Jelly Bean Dec 1, 2016
    Eshan_Anand , Dec 1, 2016 :
    true, i had it disabled and was facing the same FC issue but when enabled no more FC
  16. F_Serge_Jacquemin_ZKlt
    Cupcake Dec 1, 2016
    F_Serge_Jacquemin_ZKlt , Dec 1, 2016 :
    Merci
    Je bloque
    J ai dezipé le dossier, mais je n'arrive pas a installer.
    Dans mise a jour, aucun paramètre, juste mettre a jour.
    Comment faire
    Merci
  17. merewoodbebox
    merewoodbebox , Dec 1, 2016 :
    And let me know if your phone passes the safety net tests
  18. drbothra1
    Eclair Dec 1, 2016
    drbothra1 , Dec 1, 2016 :
    done that still facing this (screenshot) Untitled1.jpg . pls send me the link of adb 1.0.36. thanks
  19. pumba7
    Eclair Dec 1, 2016
    pumba7 , Dec 1, 2016 :
    Contacts and recent calls are white-themed and have white letters in them so things are not clear at all! Favourites are dark-themed though and seem good. Anyone else experiencing this bug??
  20. DracoSura
    DracoSura , Dec 1, 2016 :
    OK now that CB has beta 8 for testing purposes and future CBs of nougat, please give stable build of 3.5.x for OP3 @Carl @Tony L.
    We want those new features too!!!
    Archies likes this.
