477
OxygenOS Open Beta 8 (Nougat) for OnePlus 3
Thread Status:
Not open for further replies.
  1. kltshree
    Cupcake Dec 1, 2016
    kltshree , Dec 1, 2016 :
    Is this upgrade has default dialer video call option?
  2. MangoDogi
    Honeycomb Dec 1, 2016
    MangoDogi , Dec 1, 2016 :
    open command prompt elevated and try again
  3. Sun90
    Starting Point Expert Dec 1, 2016
    Sun90 , Dec 1, 2016 :
    +1
    it's a bug, I am also experiencing it.
  4. Daveensannie
    Eclair Dec 1, 2016
  5. luthnice
    Froyo Dec 1, 2016
    luthnice , Dec 1, 2016 :
    until we said that there is no more bugs and stable enough then oneplus will release the update officially
    am0udi likes this.
  6. cezarvrabie
    Jelly Bean Dec 1, 2016
    Daveensannie likes this.
  7. danimartinez95
    Gingerbread Dec 1, 2016
    danimartinez95 , Dec 1, 2016 :
    Am I the only one who has double SMS apps? I have the OnePlus and the Google, and I can't uninstall any of both apps.
    david.vahovsky likes this.
  8. jaykc
    Froyo Dec 1, 2016
    jaykc , Dec 1, 2016 :
    Bit the bullet. Now to see if it makes the difference you guys :)
  9. stephenboyo
    KitKat Dec 1, 2016
    stephenboyo , Dec 1, 2016 :
    This was exactly the same problem I encountered and couldn't even sideload stock recovery via my pc. I think it is best to not flash beta 8 via TWRP period.
    yolomofo and chuck_stones like this.
  10. pranavsuva
    Froyo Dec 1, 2016
    pranavsuva , Dec 1, 2016 :
    Please make sure that if you are on cellular data its not on roaming, else it wont work
  11. filipe.aparicio
    Ice Cream Sandwich Dec 1, 2016
    filipe.aparicio , Dec 1, 2016 :
    I know, that's what they promised by the end of November. Stable build only by the end of December or early January. So I don't understand what you mean.
  12. pranavsuva
    Froyo Dec 1, 2016
    Are you on roaming?
  13. pranavsuva
    Froyo Dec 1, 2016
    I disabled messenger. I think it was installed as part of gapps
  14. stephenboyo
    KitKat Dec 1, 2016
    Don't change Cache to f2fs. Leave it alone all you need is for data to be f2fs and that is what matters.
    James Matthew Wells likes this.
  15. ratan.paul22
    Froyo Dec 1, 2016
  16. stephenboyo
    KitKat Dec 1, 2016
    Are you rooted on beta 8?
  17. iamrajeev
    iamrajeev , Dec 1, 2016 :
    the only issues i found so far with this CB8.
    battery drain is high a bit with screen on.....as it beta so with time it should solved
  18. yolomofo
    Froyo Dec 1, 2016
    yolomofo , Dec 1, 2016 :
    any idea on how to get stock recovery back?
    filipe.aparicio likes this.
  19. humanzqzr
    humanzqzr , Dec 1, 2016 :
    use equaliser present in settings>sound>audio settings
  20. chitocr
    chitocr , Dec 1, 2016 :
    Major bugs so far? Enough for daily driver? What about battery life?. Thanks.
