477
OxygenOS Open Beta 8 (Nougat) for OnePlus 3
Thread Status:
Not open for further replies.
  1. Deactivated User
    Dec 1, 2016
  2. fc_themaster
    Eclair Dec 1, 2016
  3. jaykc
    Froyo Dec 1, 2016
    jaykc , Dec 1, 2016 :
    anyone have any problems viewing APNs? When i go into Settings / SIM & network, Choose SIM 1 and once i select Access point names... it crashes with the message "com.android.phone has stopped".
  4. cezarvrabie
    Jelly Bean Dec 1, 2016
    cezarvrabie , Dec 1, 2016 :
    You can find it here. That being said, it doesn't boot with N for me.
    yolomofo likes this.
  5. stesind
    Froyo Dec 1, 2016
    stesind , Dec 1, 2016 :
    I have just found that the dark theme accent colors are missing. Just the bright theme once are available.
  6. eddyh
    Gingerbread Dec 1, 2016
    eddyh , Dec 1, 2016 :
    Check. Same here AND no cellular data available.. I will try clean flash with full wipe tonight, unless someone has some other solution :)
  7. G_Jonathan_Dunaway_SLBW
    Eclair Dec 1, 2016
  8. maheshkumar595
    Cupcake Dec 1, 2016
    maheshkumar595 , Dec 1, 2016 :
    Thank you OP dev team.
  9. Mathias Crespi
    Cupcake Dec 1, 2016
    Mathias Crespi , Dec 1, 2016 :
    Is this build the one that should format the SDD from EXT4 to F2FS ?
    I happened to just read an article in android authority stating the major difference in speed 'tween both OP3 and OP3T was given to the change in SDD format, also they stated the open beta 8 with nougat for OP3 would provide this new SDD format.
    I'm just asking since I don't see this information in the features disclaimer at the top of the post.
    Thanks in advance people! Great job on all you do!
  10. Waffle Toaster
    Waffle Toaster , Dec 1, 2016 :
    OnePlus Community app has been removed by default so make sure to reinstall.
    Android Pay not working for me here in the UK as it does not recognize the updated software.
    merewoodbebox likes this.
  11. Scherpenseel
    KitKat Dec 1, 2016
    Scherpenseel , Dec 1, 2016 :
    If you do a full wipe and clean install then yes!
    Mika82 likes this.
  12. Mika82
    Froyo Dec 1, 2016
    Mika82 , Dec 1, 2016 :
    Installed MusicFX from play store and now i have equalizer back in Play music and other music players.
  13. managerxxx
    Froyo Dec 1, 2016
    managerxxx , Dec 1, 2016 :
    No Safetynet is not working, so as per the OP it'd be safe to assume that Android Pay is not working.
  14. G_Michal_Rodasik_ImVg
    Donut Dec 1, 2016
    G_Michal_Rodasik_ImVg , Dec 1, 2016 :
    Change your theme to stock. Many settings causes FC under dark theme.
    david.vahovsky likes this.
  15. Sun90
    Starting Point Expert Dec 1, 2016
    Sun90 , Dec 1, 2016 :
    first change theme to default and then open APN once.
    then u can revert back to dark theme.
    this way it will solve ur issue
    david.vahovsky and jaykc like this.
  16. yolomofo
    Froyo Dec 1, 2016
    yolomofo , Dec 1, 2016 :
    Yeah thats what i mean :\ It doesnt for me neither. Sucks pretty much.
  17. ath.peppas
    ath.peppas , Dec 1, 2016 :
    No problems yet, feels as snappy as before and battery life seems improved. However, I've got to wait for a week.
  18. Waffle Toaster
    Tried out the 1080P 60FPS recording mode and experiencing some choppy footage. Anyone else confirm this?
  19. sundar974
    Cupcake Dec 1, 2016
    sundar974 , Dec 1, 2016 :
    How Can I update my OnePlus 3 to the latest Oxygen OS ?
    Can someone help with the steps
  20. James Matthew Wells
    Honeycomb Dec 1, 2016
    James Matthew Wells , Dec 1, 2016 :
    I just have google now to show weather as a card and I have always had a weather card that keeps up to date on my lockscreen. At least in marshmallow I did...
    Ika Musume likes this.
