477
OxygenOS Open Beta 8 (Nougat) for OnePlus 3
Thread Status:
Not open for further replies.
  1. cohaolain
    Honeycomb Dec 1, 2016
    cohaolain , Dec 1, 2016 :
    Unofficial TWRP. Working after a clean flash. I also formatted as f2fs manually.
  2. romilbadhe
    Donut Dec 1, 2016
    romilbadhe , Dec 1, 2016 :
    Will I get f2fs file type support if I do this?
  3. bravchenko
    Donut Dec 1, 2016
    bravchenko , Dec 1, 2016 :
    Can anyone try if Netflix works properly? After this update, search and browse by categories not works well :(
  4. kmagalios
    Cupcake Dec 1, 2016
    kmagalios , Dec 1, 2016 :
    I just test it and everything works fine...
  5. sivabalan83
    Donut Dec 1, 2016
    sivabalan83 , Dec 1, 2016 :
    Hi all,
    I am able to upgrade(dirty flash) from open beta 7 to open beta 8(Android N).the following is what I did,
    1. Flashed the custom twrp-3.0.2-1.28-oneplus3
    2. Flashed the open beta 8 rom
    3. Flashed again twrp-3.0.2-1.28-oneplus3 just in case.
    4. Flashed SuperSU zip SR5
    5. Reboot
    Observations:
    1. There were two red lines "error logs" but the script succeeded.
    2. Initially there was one bootloop
    3. During boot it is going to a black screen which says D-veriety is not started in enforcing mode and the device may not function properly
    Guys please tell me how to get rid of that enforcing mode message.
    Jole7 likes this.
  6. j.pastre
    Cupcake Dec 1, 2016
    j.pastre , Dec 1, 2016 :
    Have same issue but found a workaroud : put network to 2G only then 2G/3G/4G(Auto) . Everytime you go with wifi mode and come back to cellular, you need to apply workaround again
    F_Michal_Doblej_dBkm likes this.
  7. Deactivated User
    Dec 1, 2016
  8. F_Thonz_Lagda_Turtur_Lpg
    Froyo Dec 1, 2016
  9. Nightware
    Froyo Dec 1, 2016
    pranavsuva likes this.
  10. Deactivated User
    Dec 1, 2016
  11. sammydabammy
    Cupcake Dec 1, 2016
    sammydabammy , Dec 1, 2016 :
    I know this is a similar build to the community ones that have a similar issue. I just want to know why the lock screen dimming has been removed in these versions? Personally I think it looks very silly especially when album cover art appears. If possible, is there a way to enable this feature back on?
    Apart from that i've loved this build. Everything runs very smoothly and I can't wait for the next one!
  12. OkashaBasha
    Cupcake Dec 1, 2016
    OkashaBasha , Dec 1, 2016 :
    thank you all admins and fans
    can anyone help me and tell me how to sideload this ota.
    iam on 3.2.8
    I tried to do this but every time I got error sideloading.
    I think I miss something which may be very easy but I didn't notice.
    thanks again
  13. msmatis
    Cupcake Dec 1, 2016
    msmatis , Dec 1, 2016 :
    hi,
    Iam on complet stock 3.2.8 and when I try to sideload this I get error Total xfer: 1.00x after 47% done. Any idea what can be wrong?
    Thanks.
  14. Deactivated User
    Dec 1, 2016
    ghostofcain likes this.
  15. G_Nizzy_yIEl
    Gingerbread Dec 1, 2016
    G_Nizzy_yIEl , Dec 1, 2016 :
    So now that the new beta is on Nougat one must assume that 3.5 is ready to go for the OP3?
  16. hawkeye
    Eclair Dec 1, 2016
    hawkeye , Dec 1, 2016 :
    OK guys, without telling to read whole forum etc...
    can someone confirm /deny if this will work :
    1.stock phone
    2. advanced reboot on
    3. install from there
    should this work without any data loss?
    thanks
  17. Fahad shaikh
    Eclair Dec 1, 2016
    Fahad shaikh , Dec 1, 2016 :
    I must download twrp and then install zip file from there thats it right?
  18. Deactivated User
    Dec 1, 2016
  19. DaFr0n
    Froyo Dec 1, 2016
    DaFr0n , Dec 1, 2016 :
    Depends on the current OS your on, Try going into your system settings-software update- click the gear icon and see if local is in there
  20. Deactivated User
    Dec 1, 2016
