80
OxygenOS Open Beta 9 for the OnePlus 5 and Open Beta 7 for OnePlus 5T
  1. Foo007
    Donut Apr 27, 2018
    Foo007 , Apr 27, 2018 :
    I just suggestions and I also hopefully Oneplus team add more best features to updates in OP5T .
    thx for u reply and sorry for my english is poor
  2. Sahil Kakade
    Gingerbread Apr 27, 2018
    Sahil Kakade , Apr 27, 2018 :
    I'm using the IBE TWRP for my OP5 which works for me. But when I'm flashing the Open Beta 9 ROM File it shows this "UPDATER PROCESS ENDED IN ERROR 7"
    I've flashed stock roms through TWRP before on my OP5 but this is the first time something like this has happened!
    How do I solve this issue?
    I'm using version 3.2.1.0 of IBE recovery and have flashed Magisk.
  3. omidel
    Cupcake Apr 27, 2018
    omidel , Apr 27, 2018 :
    I have updated to 8.1 (5T) and I find out 2 big issues:
    1. activateing both economys and night mode have disable allways in display. Why?
    2. answer call gesture by riseing phone to ear is not available. I have waited for this particularly that I am mad and not willing to switch to oneplus6. Please fix.
  4. FighterBoyZ
    FighterBoyZ , Apr 27, 2018 :
    I corrected myself 2 posts down my original post (op5 has this and maybe 5t too, don't know about other phones though), I didn't really search if any other phones had it but this being oneplus forum I just noted that it indeed is something that oneplus has ability to influence if they so wish to do. Which they haven't so far. A shame really since the stock camera app is inferior to Google camera.
  5. GabrielA.
    Donut Apr 27, 2018
    GabrielA. , Apr 27, 2018 :
    Hi there
    My OnePlus 5T works just fine and I can often get over 10 hours of on screen time, but..... The "double tap" to lock screen feature doesn't work with the new update. Though I can still use either of navigation buttons to use the feature, but would have preferred to be able to choose the same feature anywhere on the screen.
    Kind regards, Gabriel
    omidel likes this.
  6. 45694258
  7. leonleibo
    Donut Apr 27, 2018
    leonleibo , Apr 27, 2018 :
    hi guys,
    on latest beta 7 I have encountered a problem. when switching WiFi off, after several minutes - an hour I find WiFi turned on again automatically. I went through all the setting - always scanning is off. can someone help me how to turn off WiFi without it turned on back again?
    thank you
  8. HartiDeg
  9. Deepak_koslia
    Honeycomb Apr 28, 2018
    Deepak_koslia , Apr 28, 2018 :
    Go to launcher setting
    gotshoaib and GabrielA. like this.
  10. VIJAY216
    Ice Cream Sandwich Apr 28, 2018
  11. Rodrigo Souza Possi
    Cupcake Apr 28, 2018
  12. Lonewolfnag
    Gingerbread Apr 28, 2018
  13. OnePlus_8t
    Jelly Bean Apr 28, 2018
    OnePlus_8t , Apr 28, 2018 :
    after update to beta 7 , the device is always awake resulting a battery drainage while in standby.
    here 12 hrs usage , 10 hrs of that the device was on airplane mode
  14. G_Toni_Jerković_uDrY
    Froyo Apr 28, 2018
    G_Toni_Jerković_uDrY , Apr 28, 2018 :
    has anyone tried the new Google App 8.1 beta that supposedly brings At A Glance widget to any device? I can't get it on my OP5T. it simply doesn't show up in the widget list. Google Feed widget doesn't work either
  15. ghostpanther01
    Froyo Apr 28, 2018
    ghostpanther01 , Apr 28, 2018 :
    It doesn't show for me either. I tried it with Nova Launcher and it shows available but it displays only the date. Looks like a OnePlus Launcher limitation because I can see it on Nova.
    Also, tried it with the Pixel Launcher and it works. https://www.google.com/amp/s/www.xd...pers.com/rootless-pixel-launcher-google-feed/
    gotshoaib likes this.
  16. G_Toni_Jerković_uDrY
    Froyo Apr 28, 2018
  17. arrow1198
    Froyo Apr 28, 2018
    arrow1198 , Apr 28, 2018 :
    In new beta update there is changelog saying Double tap to lock the screen but I couldn't find any option to turn it on. how i can use it?
  18. GabrielA.
    Donut Apr 28, 2018
  19. G_T_Bennett
  20. 0pLLL
