80
OxygenOS Open Beta 9 for the OnePlus 5 and Open Beta 7 for OnePlus 5T
  1. otto2
    Lollipop Apr 25, 2018
    otto2 , Apr 25, 2018 :
    An example of a low light shot-check the Cat s eyes, their size Shows the light Situation. so you can see more Details, but also more noise, picture shot on OP5, stock cam app, Automode, no flash, freehand, no editing, just compressed to fit forum Filesize Limit. IMG_20180423_215921_001.jpg
    #81
    MikeG247 and Sun90 like this.
  2. P1520770731857
    Honeycomb Apr 25, 2018
    P1520770731857 , Apr 25, 2018 :
    The oil painting effect is still not gone, it's still there.
    Furthermore, the dots are also still there in GCAM, showing they haven't changed the HAL at all.
    So what the **** are you talking about?
    #82
  3. alogim
    Ice Cream Sandwich Apr 25, 2018
    alogim , Apr 25, 2018 :
    I just noticed a bug, which was present also in OB6 on OP 5T. When setting up the face unlock after I performed the update (since I had to disable encryption because of TWRP), the first time you unlock the screen you have to do it via fingerprint/password. Face unlock doesn't work. After that, it works, but the first time you need to unlock it manually.
    #83
  4. otto2
    Almost gone is not total gone. Better you learn to read more carefully. GCAM is not an Oneplus app. It 's an unofficial Port. So what? I m pretty sure, they will fix it one day, but most probably not before they ve optimized their very own Software.
    #84
    gotshoaib, MikeG247 and Sun90 like this.
  5. Pruthvi9277
    #85
  6. BeingIncog
    Nougat Apr 25, 2018
    #86
  7. SoniaB
    Nougat Senior Moderator Apr 25, 2018
    SoniaB , Apr 25, 2018 :
    Thread merged. Please note there is no need to open a new thread nor indeed to post the update screen. Changelog is already noted in the start post.
    #87
    otto2, MikeG247 and Sun90 like this.
  8. Pruthvi9277
    Pruthvi9277 , Apr 25, 2018 :
    thank you very much for letting me know.
    #88
  9. C1524237177334
    Cupcake Apr 25, 2018
    #89
  10. Federico_Loprior
    Gingerbread Apr 25, 2018
    Federico_Loprior , Apr 25, 2018 :
    I absolutely agree. DOTS ARE THE WORST THING OF THIS SMARTPHONE.
    #90
  11. Sun90
    Starting Point Expert Apr 25, 2018
    Sun90 , Apr 25, 2018 :
    And you are on which version right now?
    #91
  12. C1524237177334
    #92
  13. Sun90
    I am asking about the oxygenOS version.
    #93
  14. C1524237177334
    #94
  15. C1524237177334
    #95
  16. Sun90
    Then you are on the wrong thread.
    This is an open beta thread.
    In order to get open beta updates you have to be on the open beta channel.
    #96
    gotshoaib, otto2 and MikeG247 like this.
  17. sushant9us
    sushant9us , Apr 25, 2018 :
    I got this new update but the "double tap to lock screen" isn't showing up in the settings.
    #97
  18. Sun90
    Check it under launcher settings.
    ( Long press on Homescreen for it)
    #98
  19. I_am_Batman
    KitKat Apr 25, 2018
    I_am_Batman , Apr 25, 2018 :
    I don't see any dots with my Gcam..Can you show some samples?
    #99
  20. J4t1np4r3kh
    J4t1np4r3kh , Apr 25, 2018 :
    Does the Open Beta take up a lot of space?
    I ask this because for some reason the other sections under storage is showing 21.33 gb and I don't have any other files that would explain this either. Thanks for your help
