84
OxygenOS Open Beta 9 for the OnePlus 7 Pro and 7
  1. Last edited by a moderator: Feb 19, 2020
  2. Last edited by a moderator: Feb 19, 2020
  3. AndiTheBassman , via OnePlus 7 Pro , Feb 18, 2020 :
    Works like a charm for me so far. No issues and it's buttery smooth. Battery Life is good as well. Can't complain about anything
    Deactivated User likes this.
  4. GearyRenaldi
    Donut Feb 18, 2020
  5. Avider_
    Gingerbread Feb 18, 2020
    Rahul2886 likes this.
  6. Last edited by a moderator: Feb 19, 2020
  7. Rahul2886
    Cupcake Feb 18, 2020
    Rahul2886 , via OnePlus 7 Pro , Feb 18, 2020 :
    I couldnot disconnect the call using the power button
    it was ok earlier.
    I even enabled it manually from settings but still even. it's on still I am unable to cut the call using power button
  8. Last edited by a moderator: Feb 19, 2020
  9. Last edited by a moderator: Feb 19, 2020
    fidus62 likes this.
  10. Avider_
    Avider_ , via OnePlus 7 Pro Nebula Blue , Feb 18, 2020 :
    The latest beta isn't unusable, but I'm having some animation frame drops that weren't there on the previous version. There are a couple other bugs that I'm waiting to be fixed as well, but the overall experience has been positive.
  11. ksamakie
    Eclair Feb 18, 2020
    ksamakie , via OnePlus 7 Pro , Feb 18, 2020 :
    for sure there is a significant battery drain on this beta which was not on the previous version. I am running basic apps with no high-power usage and it feels that the phone doesn't last 5 hours. where on previous beta I use to get a full day heavy usage with ease.
  12. a_m28
    Ice Cream Sandwich Feb 18, 2020
    Nabin Raz Dhital likes this.
  13. AndiTheBassman , via OnePlus 7 Pro , Feb 18, 2020 :
    My battery feels really good. After 19 hours I just hit 50% with over 3 hours SoT. That's pretty good battery life imo
    A couple of small bugs here and there but nothing to bad. If you use stock google gestures with dark mode and black keyboard the bar under the keyboard sometimes is half black and half white (seems like it's only when the Nav-Bar would be displayed white like when your share a pic via WhatsApp and write a caption). With hidden navigation bar everything works just fine.
    New Download boost mode seems to kick in everytime I download an app from the AppStore. Turned it off though cause I don't really see the benefits with a good W-Lan connection.
    Deactivated User and fidus62 like this.
  14. Last edited by a moderator: Feb 19, 2020
    acarrera77, fidus62 and ksamakie like this.
  15. F1579226717741
    Froyo Feb 18, 2020
    F1579226717741 , Feb 18, 2020 :
    volume up + power button shortcut is still not possible to disable. disappointing... basic feature of Android becomes super annoying when it's not completed.
  16. OnePlusAim
    Honeycomb Feb 18, 2020
  17. OnePlusAim
    OnePlusAim , via OnePlus 7 Pro , Feb 18, 2020 :
    ? what does that shortcut do? nada on my phone
    yunnan4 likes this.
  18. F1579226717741
    Froyo Feb 18, 2020
    on Scandinavian 7t pro it enables vibrate mode without any notification symbol in statusbar. same on my Nokia 7 plus. but Android one let's me disable it.
    OnePlusAim likes this.
  19. Last edited by a moderator: Feb 19, 2020
