84
OxygenOS Open Beta 9 for the OnePlus 7 Pro and 7
  1. F1579226717741
    Froyo Feb 18, 2020
    F1579226717741 , Feb 18, 2020 :
    My girlfriend also has 7t pro. same thing happens. press them at the same time. I got oxygen version 10.0.7 with January security update.
    Aksagar1205 likes this.
  2. OnePlusAim
    Honeycomb Feb 18, 2020
    OnePlusAim , via OnePlus 7 Pro , Feb 18, 2020 :
    the T series has its on Forum, We don't even have that function
    yunnan4 likes this.
  3. J1571092570140
    Froyo Feb 18, 2020
  4. F1579226717741
    Froyo Feb 18, 2020
    good to know. I didn't now inconsistent software was a OnePlus thing. Android one and pixel phones clearly has a software advantage over oxygen.
    c.pister likes this.
  5. ksamakie
    Eclair Feb 18, 2020
    ksamakie , via OnePlus 7 Pro , Feb 18, 2020 :
    from any screen on the phone. try to access hidden space. scan finger. phone takes you to last open app and freezes. press on/off button try again and it works. hidden space apps open up.
    Saurabh_Tandon likes this.
  6. Nabin Raz Dhital
    Froyo Feb 18, 2020
  7. OnePlusAim
    ..... it's an incremental update the OnePlus 7 Pro in the OnePlus 7t Pro are not the same phone
  8. F1579226717741
    Froyo Feb 18, 2020
  9. Last edited by a moderator: Feb 19, 2020
  10. F1579226717741
    Froyo Feb 18, 2020
    your making this personal. why are you attacking me? it's not my fault OnePlus has added 1/2 of a feature. non of my other phones has ever had this issue. am I wrong for wanting the phone to actually work? when this shortcut is activated it vibrate ones after caller hangs up.
  11. OnePlusAim
    let's break this down homie
    first you're upset posting in the wrong section of the forums
    second you are aware of what's going on in China right now correct?
    3rd we all love one plus we understand that there are concept phones older phones that need updates as well as the new ones and they're on the verge of releasing a brand new phone all together.
    let's recap coronavirus, Chinese New year, new releases.
    are we on the same page now do you understand because you came in here being rude in the wrong spot voicing an opinion and complaints about a feature that we don't have so we couldn't possibly help you with unless you happen to have the luck of the draw and one of the other peoples in here posting regularly on the OnePlus 7 Pro and OnePlus 7 also have the OnePlus 7t/Pro.
    if you're looking for help by all means hop in your forum let it be known let the bug report make it let there be a fix. don't go into the wrong section of the forums and bitching about how they can't ******* keep everything uniform not all of these phones have the same hardware my dude. if it is that much of an issue you have a plethora of ROMs that you could try that may be more towards your liking with all of the features that you so desperately need
  12. F1579226717741
    Froyo Feb 18, 2020
    this is not a new problem. it's been on several OnePlus models for several years. I'm disappointed about OnePlus costumer support. this shouldn't be a issue at all.
  13. Didit_Anshari
    Gingerbread Feb 18, 2020
    Didit_Anshari , via OnePlus 7 Pro , Feb 18, 2020 :
    Is this all about vibrate mode that had notification on the status bar ? And the problem is you cant disable it ? I mean wtf
    yunnan4 and OnePlusAim like this.
  14. F1579226717741
    Froyo Feb 18, 2020
    it is about OnePlus phone going silent when you don't want them to. do I even need an alert slider when it's disabled by a easy to press vibrate mode shortcut? phone in normal mode on the alert slider and it only vibrates after calls. not very intuitive.
  15. Udaydas833
    Eclair Feb 18, 2020
  16. Saurabh_Tandon
    Eclair Feb 18, 2020
    Saurabh_Tandon , via OnePlus 7 Pro , Feb 18, 2020 :
    I too have the same issue..if someone has found a fix please enlighten! thanks
    ksamakie likes this.
  17. Didit_Anshari
    Use feedback - Suggestion, tell them whatever you want. If enough people demand it maybe they consider to bring em back. Personally idc about those, im just hoping they put Optimized charging feature to stable
    OnePlusAim and Udaydas833 like this.
  18. Last edited by a moderator: Feb 19, 2020
    OnePlusAim likes this.
  19. OnePlusAim
    this is interesting I've never seen this issue
  20. Last edited by a moderator: Feb 19, 2020
