84
OxygenOS Open Beta 9 for the OnePlus 7 Pro and 7
  1. VaibhavBhargava
    Lollipop Feb 20, 2020
    VaibhavBhargava , Feb 20, 2020 :
    The back button of the keyboard looks weirdly placed.
    The new dark theme UI for the sub settings and settings shortcut looks odd and ugly.
  2. VaibhavBhargava
  3. G_Sourav_Chakraborty_Xgt
    Gingerbread Feb 20, 2020
  4. VaibhavBhargava
    It was already at its appropriate setting of font size default and display size of custom DPI 432.
    The normal (main) settings UI and the rest of the phone is alright. It is just all subsequent settings menu and the settings shortcut are all messes up.
  5. VaibhavBhargava
    No, they aren't.
    The main settings app.
    The font size and display size settings
    Custom override for display size
  6. VaibhavBhargava
    [QUOTE="L1558132372146, post: 21349252, member:2512402"]Do you have any other apps on your phone that affects screen display or have you made any changes in Developer Options that effect the screen?
    As I mentioned earlier the rest of the apps are alright.
    It's their goof up on the settings app.
  7. VaibhavBhargava
    That change has been present from a long time before updating to OPB9.
    I also used it in OP3T.
    In any case if I set it to some other value ar set it as default, it will affect the other apps scaling, which is alright to begin with. The issue is only the few screens of the settings app and shortcut settings screen.
  8. adeel.mirza
    Cupcake Feb 20, 2020
  9. X1568888095586
    Gingerbread Feb 21, 2020
    X1568888095586 , via OnePlus 7 Pro , Feb 21, 2020 :
    Then when stable user will get optimized charging feature for 1+7pro?any improvements in stock cam software? I think it must improve, I am using most of the time gcam
  10. X1568888095586
    Thanks for your cooperation, actually I am not so much worried bt curiosity grown up seeing beta user gets more benefit, they get all features before stable update that's y I was curious about that. Do you prefer stable thn beta WHT do you think which one is better for me? Tell me /suggest me one think when I bought this phn the seller assured me that my device is global rom though I have not so much well known about global rom variations like [e]1f1e8_1f1f3[/e] rom, EU stable rom, Indian rom Etc. My device is China rom variant & I want to stable global rom, currently I have GM 1910 21BA,10.0.4 stable, one plus 7 pro (EU) & I am using Oxygen updater, I want to go back from China Rom to International global Rom i. E from GM21BA to GM 21AA, plz suggest which way I can follow
    Deactivated User likes this.
  11. Last edited by a moderator: Feb 21, 2020
  12. SWAPPYONE
    Honeycomb Feb 21, 2020
    the_reckoner likes this.
  13. Dr.Bhrajishna
    Cupcake Feb 21, 2020
    Dr.Bhrajishna , via OnePlus 7 Pro , Feb 21, 2020 :
    updated.. Been using for last 2-3 days. it is draining battery more than usual. what about others. I used to get screen on time of 5-6 hrs. Currently getting 3-4 hrs. What about others?
  14. joydeep33.dey
    Eclair Feb 21, 2020
