84
OxygenOS Open Beta 9 for the OnePlus 7 Pro and 7
  1. GraveDigger176
    Gingerbread Feb 22, 2020
    DMaarten likes this.
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Feb 22, 2020
    Swejuggalo , via OnePlus 7 Pro , Feb 22, 2020 :
    Sure the slider to the right reacts and works when you slide up and down? Sounds like it is in the middle position
  3. R1561598923024 , via OnePlus 7 Pro , Feb 22, 2020 :
    Swejuggalo
    as you see in the picture the middle is no highlighted so I can press on the ringtone icon or slide the slider on the menu or settings menu. yes I'm talking about the middle one.
    such a weird bug
    thank for the reply! updated comment to make it more clear
  4. yunnan4 likes this.
  5. Swejuggalo
    There is a physical slider. Checked its position? You can't change sound if it is in vibrate or mute mode
    Deactivated User likes this.
  6. Last edited by a moderator: Feb 22, 2020
  7. karthiklachchu
    Eclair Feb 22, 2020
  8. Cervantes
    Moderator Moderator Feb 22, 2020
    Cervantes , Feb 22, 2020 :
    Hi
    the beta thread is a question and comment thread
    Use the search engine before opening a new thread
    Thread merged
  9. yunnan4
    Eclair Feb 22, 2020
    yunnan4 , via OnePlus 7 Pro , Feb 22, 2020 :
    karthiklachchu
    lam using OnePlus 7 pro beta 9. how to enable override force dark mode.​
    It's been removed. Try using DarQ from XDA. [e]1f44d[/e]
  10. R1561598923024 , via OnePlus 7 Pro , Feb 22, 2020 :
    I have no utility apps installed on my phone. it's 100% stuck because of the update not a 3rd party app.
    I don't even really get the point of a volume locker app.
    some background info about me so I don't seem like an idiot like I am currently apparently.
    I have been tinkering with beta OS' ever since Blackberry 4 OS, which was 18 years ago. I was obsessed with crackberry until bb10.3, the time i gave up my passport.it was my last blackberry. I had various curves and bolds with a total around probably 10 because I wasn't keeping them for a year even before getting the newest one. once bb10 came out, I got the z10 on release, then q10, then passport. All 10+ of those phones I was using the full wipe betas/alphas via usb.
    apple tv 1and 2 I jailbroke for kodi when it was actually good. now Kodi is the worst way for IPTV/on demand and I have a Nvidia shield plus great gaming computer for that.
    after BB passport I messed with CyanogenMod. but, in the past 5 years I have been doing the more conservative OTA betas due to not liking tinkering as much as I use to and ease of use.
  11. karthiklachchu
    Eclair Feb 22, 2020
    karthiklachchu , via OnePlus 7 Pro , Feb 22, 2020 :
    [e]1f44d[/e]
  12. B!l@l
    Cupcake Feb 22, 2020
  13. B!l@l likes this.
  14. KarthikChikki
    Donut Feb 22, 2020
    KarthikChikki , via OnePlus 7 , Feb 22, 2020 :
    So many bugs in Open Beta 9 in OnePlus..
    there is Android 10 left and right gestures appearing when you open keyboard.. in full screen gestures bottom..
    when we navigate back gesture, the screen will slightly moving.. i mean scrolling..
    pls fix this issues as soon as possible..
    i don't want to wait for the next open beta..!!
    ASAP!!
  15. Cervantes
    Hi
    Please read the first post
    Thread merged
  16. Swejuggalo
    When you use the slider it shows ring, vibrate and silent as it should? As someone mentioned... If you don't have any 3rd party app that can change sound settings verifiy that the slider is not broken
  17. Swejuggalo
    If you use the latest stable you probably have a newer OS than beta 9. So to fix that you need to downgrade to 9 and thus get the phone wiped.
    Then download and install beta 5 (see first post) and upgrade via OTA up to beta 9.
    Or wait for beta 10 and and download full zip and install over current stable and you will avoid a few steps. Going back to stable will often cause a wipe too...
    Sources of full zip files
    OnePlus[e]2122[/e]
    Everything OnePlus #NeverSettle
    Not endorsed by OnePlus
    https://t.me/OnePlus
    (open up with Telegram app)
    Or
    https://swejuggalo.blogspot.com (for torrents)
    Or
    Oxygen Updater
  18. Viksjnn
    Donut Feb 22, 2020
    Viksjnn , Feb 22, 2020 :
    Camera is zooming in weirdly in photo mode, seems like they have updated the focal length, seems like by default its zooming in 1.3X which can't be disabled and all the photos are zoomed in.
