84
OxygenOS Open Beta 9 for the OnePlus 7 Pro and 7
  1. elanglois
    Lollipop Feb 24, 2020
    elanglois , via OnePlus 7 Pro , Feb 24, 2020 :
    Bluetooth audio works fine, but if you have Android Auto, why would you use lossy Bluetooth?
    I think your car head unit is set for Android Auto. You'll need to tell it to switch inputs back to Bluetooth if you want to use Bluetooth. That's how my Chevy works. Your phone is fine. You just don't know how to operate your car.
    OnePlusAim likes this.
  2. elanglois
  3. elanglois
    nope. no such issue. test on another wifi.
    my bet is something on the network is set to use the same IP address. is everything set to use dhcp, or are some statically assigned?
  4. elanglois
    Samsung is patching bugs that THEY created by doing things Google said not to do.
    https://www.sammobile.com/news/google-slams-samsung-making-unnecessary-changes-linux-kernel-code/
    https://www.zdnet.com/article/googl...nux-kernel-code-its-hurting-android-security/
    So yeah, go get a Samsung with REAL security issues. Most of the Google issued fixes are not critical and it does take time to test and implement.
    yunnan4 and L1558132372146 like this.
  5. elanglois
    You are taking it off the charger huh? You don't let it charge overnight, right? How did I know?
    If you want your phone to optimize properly you HAVE let to let it stay plugged in ALL NIGHT.
    K1560976949282 likes this.
  6. Jay2020
    Ice Cream Sandwich Feb 24, 2020
    Jay2020 , via OnePlus 7 Pro , Feb 24, 2020 :
    You can run the current already installed Update or a newer update. As you can see I am currently on Open Beta 9 and in the Updater I have the option to download again Open Bata 9. Then to Settings, Local Update. Only current or newer.
  7. Swejuggalo
    KitKat Feb 24, 2020
    Swejuggalo , via OnePlus 7 Pro , Feb 24, 2020 :
    Yepp. Downloading the same version and reinstall that works too. Otherwise only upgrades based on dates no matter if it's stable or beta.
    OnePlusAim and L1558132372146 like this.
  8. Jay2020
    I'm so glad to be done with Samsung phones. Samsung has never ran this good. OnePlus 7 Pro [e]1f44d[/e][e]1f44d[/e][e]1f44d[/e][e]1f44d[/e][e]1f44d[/e].
  9. lionsvideogame
    Cupcake Feb 24, 2020
    lionsvideogame , Feb 24, 2020 :
    Hi!
    when will we get Android 10 for OnePlus 7 Pro 5G?
    Thank you in advance for your kindly response.
  10. balenax
    Eclair Feb 24, 2020
    balenax , via OnePlus 7 Pro , Feb 24, 2020 :
    I am on 10.0.4 and want to go back to the beta. is there any way to flash it without wiping the phone? I've downloaded open beta 9 and cannot apply it, I get a message telling me that the installed version is newer and I'm unable to downgrade. thanks in advance.
  11. brian.sedore
    brian.sedore , via OnePlus 7 Pro , Feb 24, 2020 :
    As much as I would like to try it, because it's not on the official store, I'll have to pass. I have heard good things about it though.
  12. Jay2020
    Check the very beginning of this thread for best advice about switching to beta.
  13. Y1581104362215
    Y1581104362215 , via OnePlus 7 Pro , Feb 24, 2020 :
    Noticed today, when searching for a contact, the results show double entry, one in my Google account and other in 'Work Directory', while it has been selected only to display the contacts in the Gmail account.
    Any idea why and what to do about it?
    zeb_bwp likes this.
  14. Shajahankm
    Gingerbread Feb 24, 2020
  15. karthikcpt
    Cupcake Feb 25, 2020
  16. Jay2020
    Ice Cream Sandwich Feb 25, 2020
    Jay2020 , via OnePlus 7 Pro , Feb 25, 2020 :
    Not understanding. Are you saying there is a time difference between the clock on your notification bar and a widget clock on your desktop?
  17. karthikcpt
    karthikcpt , via OnePlus 7 , Feb 25, 2020 :
    L1558132372146
    Not understanding. Are you saying there is a time difference between the clock on your notification bar and a widget clock on your desktop?​
    Yes, especially when watching the YouTube videos, notification bar time not updated
  18. Jay2020
    First, try rebooting the phone. The clock in the bar is likely correct. It's likely the widgets failing to refresh.
  19. Jay2020
  20. karthikcpt
    L1558132372146 likes this.
