84
OxygenOS Open Beta 9 for the OnePlus 7 Pro and 7
  1. Sagarbudhani
    Donut Feb 25, 2020
  2. zeb_bwp
    Froyo Feb 25, 2020
    zeb_bwp , Feb 25, 2020 :
    Same issue here, were you able to find some solution for this? Anyone here who can help, please.
  3. elanglois
    Lollipop Feb 25, 2020
    elanglois , via OnePlus 7 Pro , Feb 25, 2020 :
    it will never be in the official store! but why should that matter?
    L1558132372146 likes this.
  4. elanglois
    then your car is at fault most likely. nothing wrong with the Bluetooth. is your car set to play from your device? what kind of car?
  5. yunnan4
    Eclair Feb 25, 2020
  6. Rahul Jumani
    Cupcake Feb 25, 2020
    Rahul Jumani , via OnePlus 7 , Feb 25, 2020 :
    after the update, fingerprint scanner is getting disabled often. rebooting phone again and again to enable it.
    anyone facing the same issue or is it a hardware problem?
  7. Swejuggalo
    KitKat Feb 25, 2020
    Swejuggalo , via OnePlus 7 Pro , Feb 25, 2020 :
    No issues here... But mine is a 7 Pro
  8. James Matthew Wells
    Honeycomb Feb 25, 2020
    James Matthew Wells , Feb 25, 2020 :
    I have had this happen a couple of times. Minor annoyance. I am sure the next update will fix it. If it occurs again or gets worse, I will try a re-install of Beta 9 again (I always do the full zip each time I update, so I am not sure it will help, but it might).
    Rahul Jumani likes this.
  9. Auristic
    KitKat Feb 25, 2020
    Auristic , Feb 25, 2020 :
    Why did you open a useless and redundant thread instead of posting in the beta thread for your device (I'm sure if you try to read it first you won't even have to post since you'll find the reply inside)?
  10. Bala_Narendra_Kumar_Ch , via OnePlus 7 , Feb 25, 2020 :
    Auristic
    Why did you open a useless and redundant thread instead of posting in the beta thread for your device (I'm sure if you try to read it first you won't even have to post since you'll find the reply inside)?​
    I've not found a proper response, so opened a new thread(I'm not aware of beta version thread, bit new here)...
    and I might have misunderstood or they said in tricky way while installing... I've been in impression that, if you install beta, you can't get normal version yourself, but they will release a normal version for you, but not like you will forever stay in beta... (in nut shell I thought, I will be in beta version until all bugs fixed and they release a final, something like play store or windows where you will be jumbling between beta and regular)
    to re iterate is there a way , back door or something?
  11. Cervantes
    Lollipop Moderator Feb 25, 2020
    Cervantes , Feb 25, 2020 :
    Hi
    the beta thread is a question and comment thread
    Please read the first post
    Use the search engine before opening a new thread
    Thread merged
  12. Swejuggalo
    KitKat Feb 25, 2020
    To go back to stable without a wipe you need an unlocked bootloader and adb and/or TWRP... To unlock bootloader there will be a wipe... So...
  13. akks
    Jelly Bean Feb 25, 2020
    Swejuggalo likes this.
  14. Sagarbudhani
    Donut Feb 25, 2020
    Sagarbudhani , Feb 25, 2020 :
    No buddy it's working on my friends op7 pro on beta 8 after update it's bug in bluetooth
  15. Jay2020
    Gingerbread Feb 25, 2020
    Jay2020 , via OnePlus 7 Pro , Feb 25, 2020 :
    Fingerprint lock fresh start, try deleting your fingerprint locks setup, return to your home screen, reboot, then setup fingerprint lock again. .
  16. Rahul Jumani
    done that, still happening.
    I'll wait for the next update to get fixed OR will do a full wipe if it doesn't get fixed....
  17. DMaarten
    DMaarten , Feb 25, 2020 :
    I also noticed that Bluetooth is working less since OB9, had no problem watching video with screen share on OB8, but with 9 it stutters and disconnects frequently. Excited for OB10 :)
    OnePlusAim likes this.
  18. elanglois
    yet I use it all the time and it works fine. you probably just need to switch input from his phone to yours. Bluetooth didn't change from beta 8 to 9.
