84
OxygenOS Open Beta 9 for the OnePlus 7 Pro and 7
  1. khaleel1025
    Cupcake Feb 28, 2020
    khaleel1025 , Feb 28, 2020 :
    Dear Oneplus team, I am using OnePlus 7 Pro device and while taking selfies in normal mode, the view it is showing is a cropped picture but this problem is not there on portrait selfie shots. If the portraits are taking the correct picture covering more angle for selfies, then why this problem is there on normal selfie pictures. I hope this problem may be solved by a software update.
  2. Swejuggalo
    KitKat Feb 28, 2020
    Swejuggalo , via OnePlus 7 Pro , Feb 28, 2020 :
    It's these tiles I'm talking about
    Created with Tiles app. Once again. Hardware button overrides the software. You can however enable vibrate or silent mode without using the button. So I basically always have the button in ring mode and only use the tile.
    KishanGarach likes this.
  3. L1582911497271
    L1582911497271 , Feb 28, 2020 :
    Hy guys my Amazon application and What's app application are crashing continuously .. Is anyone facing this kind of issue ..What is the solution for this...???
  4. toavinashgupta
  5. DMaarten
    Honeycomb Feb 28, 2020
    DMaarten , Feb 28, 2020 :
    There is a lovely little search button, asked and answered many many times
  6. Jay2020
    Honeycomb Feb 29, 2020
    Jay2020 , via OnePlus 7 Pro , Feb 29, 2020 :
    At the very top of this thread is some very good instructions on how to do that. [e]1f601[/e][e]1f44d[/e]
  7. OnePlusAim
    the_reckoner and L1558132372146 like this.
  8. Jay2020
    OnePlusAim likes this.
  9. Jay2020
  10. eastFIN
    Cupcake Feb 29, 2020
    eastFIN , via OnePlus 7 , Feb 29, 2020 :
    I've had this same bug on my OP7. Fixed it by unpairing my bluetooth device and pairing it again. I did have this same bug on my previous phone (HMD Nokia) too...
  11. Fererio
    Eclair Mar 1, 2020
  12. Dinpai7
    Froyo Mar 1, 2020
    Dinpai7 , via OnePlus 7 , Mar 1, 2020 :
    Its not only in bluetooth but Normal speaker volume is also very low..is it because of bug?
  13. OnePlusAim
    Honeycomb Mar 1, 2020
    OnePlusAim , via OnePlus 7 Pro , Mar 1, 2020 :
    that's interesting. sometimes these bugs arise during an update typically an older package doesnt remove an older file for the previous version and often a Factory Reset Fixes these issues.
    I Am Personally not having issues with Volume of anything some times it's alittle too loud
    Dinpai7 likes this.
  14. Carlapopprincess
    Cupcake Mar 1, 2020
  15. DMaarten
    Honeycomb Mar 2, 2020
  16. C1567789324865
    Cupcake Mar 2, 2020
  17. nikhil_alex
    Donut Mar 2, 2020
    nikhil_alex , Mar 2, 2020 :
    device oneplus 6 is getting heated by just using instagram and whatsapp even though the charge is above 70%
    before android 10 i used to play pubg in 10% charge and the device never heated up, I did cache clear nd all stillm..
    this is very inconvenient and annoying, didnt expect this from OnePlus
  18. Dinpai7
    Froyo Mar 2, 2020
    Dinpai7 , via OnePlus 7 , Mar 2, 2020 :
    Thank You So Much for kind reply, jus wanted to know if I again download the full ROM and install will it help cos factory reset will delete all data but if factory reset is best then will go ahead with that Pls Advise
  19. DMaarten
    DMaarten , Mar 2, 2020 :
    https://forums.oneplus.com/forums/OnePlus6-6T/
  20. Jay2020
    Jay2020 , via OnePlus 7 Pro , Mar 2, 2020 :
    I'm having no issues with Android 10, Open Beta 9 and liking it. You really aren't missing much still being on Android 9. Nine was very functional and solid.
