290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. James Matthew Wells
    Honeycomb Dec 19, 2016
    James Matthew Wells , Dec 19, 2016 :
    I am seeing an excessive data connection now too... Hmmmm...
    jstiggie likes this.
  2. fxguru77
    Jelly Bean Dec 19, 2016
    fxguru77 , Dec 19, 2016 :
    Battery drain seems to happen after the Google app update every time the app gets updated the drain starts and it takes 1day or 2 until it gets normal
  3. James Matthew Wells
  4. Jac_Q
    Ice Cream Sandwich Dec 19, 2016
    Jac_Q , Dec 19, 2016 :
    Had this, too.
    A reboot fixed it for now. Maybe it was a "one timer".
    €: And 22 minutes ago it started again ... **** that.
  5. jatinkalra07
    Gingerbread Dec 19, 2016
    jatinkalra07 , Dec 19, 2016 :
    Okay
  6. jatinkalra07
    Yes - same here. Already raised.
    CorruptComputer likes this.
  7. jatinkalra07
    Both are already fixed,
  8. gianstevens
    gianstevens , Dec 19, 2016 :
  9. Preet Parekh
    Donut Dec 19, 2016
    matuka likes this.
  10. somvirbhoria
    Donut Dec 19, 2016
    somvirbhoria , Dec 19, 2016 :
    After upgrading to Android N Google Play apps not downloading in Roaming through Mobile Data, what to do?
  11. TenzoNakami
    Donut Dec 19, 2016
    TenzoNakami , Dec 19, 2016 :
    Hi guys, I'd love to know how to add "Screenshot" to the power button menu just like the non community build does?
  12. JoaoLetelier
    Froyo Dec 19, 2016
    JoaoLetelier , Dec 19, 2016 :
    Ok so I've realised they I'm getting horrendous battery life (stand by time, to be specific). Is it possible to move to another rom without wiping the internal storage? What will happen if I try to flash CM14 from TWRP?
  13. Jac_Q
    You don't have to wipe the internal storage.
    System, cache, dalvik and data are sufficient.
  14. resporival
    resporival , Dec 19, 2016 :
    Sometimes Quick reply from statusbar not working. Sometimes need to click two times and same text send 2 times..
  15. JoaoLetelier
    Froyo Dec 19, 2016
    To do what? Go back to a MM stock based ROM, or for CM??
  16. Vishal_pipal
    Froyo Dec 19, 2016
    Vishal_pipal , Dec 19, 2016 :
    Notifications stay only for a while (10 to 15 seconds) and then they disappear from the notification bar.
    Is it just me or are u guys facing the same thing? Let me know, thanks
    inkaine likes this.
  17. sujiaero
    Cupcake Dec 19, 2016
  18. JoaoLetelier
    Froyo Dec 19, 2016
    This is happening to me but only with WhatsApp. After a certain period of time, the little WhatsApp logo disappears from the notification area all on its own, even if I haven't opened the app.
  19. arpaniitb
    arpaniitb , Dec 19, 2016 :
    Hi
    I am not able to download anything from play store after updating to OS version 9
  20. G_BMWKante_vKip
    Donut Dec 19, 2016
