290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. Jamesst20
    Jelly Bean Dec 19, 2016
    Jamesst20 , Dec 19, 2016 :
    Amazing update! Everything works 100% fine on my side. I did a clean install. The APN must be set manually for Koodo Mobile, otherwise no mobile data.
    Other than that, the battery life is very bad. In battery settings, it says that "Android System" is the biggest drainer. 35% of drain by "Android System" in average.
    The phone doesn't make the day anymore
  2. fromdau
    Cupcake Dec 19, 2016
    fromdau , Dec 19, 2016 :
    adding to the list of issues or bugs..
    +Group MMS (inbound)
    when a party replies to a group MMS it comes up a single text
  3. Jdickie23
    Gingerbread Dec 19, 2016
    Jdickie23 , Dec 19, 2016 :
    Are you putting these bugs in to the form mentioned on post 1 ? Otherwise the dev's most likely won't see them.
    otto2 likes this.
  4. Vishal_pipal
    Froyo Dec 19, 2016
    Vishal_pipal , Dec 19, 2016 :
    Happens to me for whatsapp, snapchat, Instagram :/
  5. therang
    therang , Dec 19, 2016 :
    Is it just me or is the battery life worse on Beta 9? Beta 8 seemed pretty good.
  6. chetan sannotra
    chetan sannotra , Dec 19, 2016 :
    sun90
    Both files gave same data no difference between them either we update from 1.4gb or 118 mb... Make no difference. right? Both r same thing
  7. memys21
    memys21 , Dec 19, 2016 :
    I don't think that is problem with OP3 but with Jio. I am using it from past three months and speed is getting reduced every day.
    otto2 likes this.
  8. MikeL333
    Froyo Dec 19, 2016
    MikeL333 , Dec 19, 2016 :
    There's a huge difference between these two files. The 118MB OTA update is only for updating with stock recovery from Beta8 -> Beta9. The downloadable 1.4GB file is the full ROM that can be used to flash the complete Beta9 OOS.
    otto2 likes this.
  9. chetan sannotra
    So should I update my phone with 1.4 gb ram instead of 118mb because I did both makes no difference to my mobile both r same... Even they're different files.... But I concerned about their impact on my phone
  10. mikedmontgomery
    Froyo Dec 19, 2016
    mikedmontgomery , Dec 19, 2016 :
    Bit of an odd one, but I don't seem to be able to select Spotify to be my default music player.
    When I pair to car Bluetooth it keeps opening Google Play for music instead but I'd rather it be set to Spotify. Seems weird it's not in list of apps in list to be selected as default.
    Anyone else notice this?
  11. MikeL333
    Froyo Dec 19, 2016
    If you were on Beta8 then it makes no difference which one you used.
  12. Mann108
    Mann108 , Dec 19, 2016 :
    Android system 24% battery usage. Increasing my the day. Very concerning
    MaitiuB likes this.
  13. F_Tony_DeMartino_hjHI
    Ice Cream Sandwich Dec 19, 2016
    dermot33 and xythiii like this.
  14. tomelwood
    Honeycomb Dec 19, 2016
    tomelwood , Dec 19, 2016 :
    reverted back to 3.1.2 to see how things have progressed, battery life, headphone jack sound quality and especially fingerprint unlock speed is better on 3.1.2 than on 3.2.8, any of the community builds or open Betas.
    mtbgus likes this.
  15. HarryRag
    HarryRag , Dec 19, 2016 :
    What is the problem with 4G+ , I'm nearly constant on it without problems on the countryside in NL.
    Works like a charm in areas of NL which are known for bad reception.
  16. simonone
    simonone , Dec 19, 2016 :
    I know some people are having battery life problems. For me, however, with completely stock set-up, locked bootloader, the battery life is by far the best I've had since I bought the OP3 on the day of its release. Screenshot_20161219-220218.png
  17. JJepse
    Donut Dec 19, 2016
    JJepse , Dec 19, 2016 :
    Am I able to flash stable version over this one or do I need to submit an ticket in order to do that?
  18. resporival
    resporival , Dec 19, 2016 :
    First time it was okay. SOT was 5 hr ++ but suddenly Android System taking Huge battery. Is anyone facing the same..!?
    G_Diego_Hidalgo_yeCq likes this.
  19. sammerasker
    sammerasker , Dec 19, 2016 :
    actually even me on a complete stock with TWRP and root (and some debloat) and I have a satisfactory battery
    I get around 8 to 10 SOT sending on day to day usage ,
    there are few bugs here and there , but so far tolerable.
  20. Chasticot
