290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. F_Thonz_Lagda_Turtur_Lpg
    Froyo Dec 20, 2016
    F_Thonz_Lagda_Turtur_Lpg , Dec 20, 2016 :
    yeah, me too not always but apps do crashes sometimes i need to report this issue
    Anmolpranit likes this.
  2. tremore
    Donut Dec 20, 2016
    tremore , Dec 20, 2016 :
    Dont have aggressive doze on but already after a couple of charges im getting better battery over on the official ROM.
    I did calibrate the battery by letting it go to zero and charging to full while the device was off though, dont know if that had anything to do with the SOT im getting.
    Cant put the phone on vibrate only from the sound slider tho, or from anywhere it seems, so if anyone knows how to do that or if its just a bug?
  3. Michael156
    Ice Cream Sandwich Dec 20, 2016
    Michael156 , Dec 20, 2016 :
    So today I decided to upgrade my phone to this ROM, all was well until I decided to reboot. Now I'm unable to turn on the phone as it keeps getting stuck at the decryption screen. I have had the same pass pattern for a few years now so I know it is correct, yet the device keeps failing to decrypt. This is ridiculous as seemingly the only way to turn on my phone will be to wipe all my data.
  4. inffy
    KitKat Dec 20, 2016
    inffy , Dec 20, 2016 :
    There is no such option on the ROM at the moment. I hope they will implement it for the final version
    Sahilkum and Crosswind like this.
  5. inffy
    KitKat Dec 20, 2016
    You probably have twrp which is no way officially supported
    otto2 likes this.
  6. gohanssj98
    Eclair Dec 20, 2016
    gohanssj98 , Dec 20, 2016 :
    if I sideload the beta 9, when I go back to stock Android will all my data be lost?
  7. Michael156
    I just used the recovery I was told to use by a tutorial. What recovery should I have installed?
  8. pradha91
    Honeycomb Dec 20, 2016
    pradha91 , Dec 20, 2016 :
    looks great. im on 3.2.8 and getting a max of 6 hrs SOT, with aggressive doze enabled on Nougat an extra of 2-3 hours in is awesome :) just wondering that OP3T guys will enjoy like 10+ hours of SOT haha :)
  9. tremore
    Donut Dec 20, 2016
    "There is no such option on the ROM at the moment. I hope they will implement it for the final version"
    Oh, thats weird. Yeah hoping for the option to not have to have a phone that only rings i guess, lol.
  10. Mario.Cano.Diaz
    Cupcake Dec 20, 2016
  11. Bigbabba
    Froyo Dec 20, 2016
    Bigbabba , Dec 20, 2016 :
    Dirty flash on installed Beta brings back the same problem with dm varity. With devine beats Viper4Android OP3 goes hot!
  12. Jac_Q
    Jac_Q , Dec 20, 2016 :
    Only if you install via TWRP. Go back to stock recovery if you need to have secured boot enabled.
    71 others likes this.
  13. Haroon117
    Haroon117 , Dec 20, 2016 :
    Do you mean you can't get past your lockscreen?
  14. Michael156
    No I meant that the device would not get past the pre-boot pattern. This is before android or the recovery have a chance to load
  15. Crosswind
    Froyo Dec 20, 2016
    Crosswind , Dec 20, 2016 :
    well which recovery were you told to use? the update process should've just been that you plug your phone into your computer, boot into the stock recovery and hit sideload via USB and then flash it from the command line
  16. G_BMWKante_vKip
    Donut Dec 20, 2016
  17. G_Marco_Mantegazza_nvBx
    G_Marco_Mantegazza_nvBx , Dec 20, 2016 :
    Has anyone experienced a little hang with black screen after fingerprint unlock? It doesn't happen every time but only sometimes and I can't understand the cause. I use Nova Launcher and I've done cache wiping
  18. ghostofcain
    Marshmallow Dec 20, 2016
    ghostofcain , Dec 20, 2016 :
    I think you may need to check your settings > alert slider > silent and turn on vibrate.
  19. G_FAISAL_AL-SRORRY_ycvZ
  20. viveknaudiyal
    Gingerbread Dec 20, 2016
    viveknaudiyal , Dec 20, 2016 :
    I only get 2.5 hrs sot with 500mah consumed.
    The only problem I am facing is screen on time consuming a lot battery
