290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. Quam
    Ice Cream Sandwich Dec 14, 2016
    tmalkiew likes this.
  2. JasonMR
    Lollipop Dec 14, 2016
    JasonMR , Dec 14, 2016 :
    Installed via OTA from Open Beta 7, seems fine so far, will see how it goes over the next few days.
    otto2 likes this.
  3. narreduen
    Cupcake Dec 14, 2016
  4. mmgherasim
    Froyo Dec 14, 2016
    mmgherasim , Dec 14, 2016 :
    Where was that setting ? How did I miss it ? :)
  5. G_Michał_L_yURu
    Eclair Dec 14, 2016
  6. Quam
  7. Khadkapranav
    Eclair Dec 14, 2016
    Khadkapranav , Dec 14, 2016 :
    Currently on OB8, I do have the option though. An
    yway you are welcome. Hope your problem is solved on OB9
    otto2 likes this.
  8. SoniaB
    Nougat Head Moderator Dec 14, 2016
    SoniaB , Dec 14, 2016 :
    That is weird.
    You are entering the correct commands? adb recognizes your device no problem?
  9. Crankyyy
    Crankyyy , Dec 14, 2016 :
    Hello Guys,
    i need your help. I had installed the Open Beta 8 on my OP3. Today i tried to update to Open Beta 9, but it didnt boot the system, it always boots into recovery. Already tried to reinstall everything using the method in the third post of this thread:
    http://forum.xda-developers.com/onep...3-5-5-t3490939
    Unfortunately nothing helps. I can only install the modified TWRP 3.0.2-1.28. But when i flash a rom and want to boot into it, it just boots into recovery. Tried flashing Open Beta 8 and 9. When i flash it say:
    Patching system image unconditionally...
    E:unknown command [log]
    Writtung static_nvbk image...
    Patching firmware images...
    script succeeded: result was [1.000000]
    Updating partition details...
    ...done
    Dont know if there is an error.
    After installing, when checking the /system folder through the File manager of TWRP its empty.
    Would be nice if someone can help
  10. Quam
    Quam , Dec 14, 2016 :
    Install oxygen recovery, first reboot gave me an error but after another reboot it boots fine. Afterwards I switched back to TWRP.
  11. halloarno
    halloarno , Dec 14, 2016 :
    Did you still have your sim active with sr5 SuperSU zip? Cause with normal SU i lost the both sim's.
    narreduen likes this.
  12. Wildvine
    Gingerbread Dec 14, 2016
    Wildvine , Dec 14, 2016 :
    Sounds good that OB7 got the OTA also.. Wondering if we can easily downgrade to MM (not my choice anyway) unlike the previous build..
  13. DracoSura
  14. stephenboyo
    KitKat Dec 14, 2016
    stephenboyo , Dec 14, 2016 :
    I dirty flashed it via twrp over CM14 and it installed without any problems. All data and apps intact.
  15. akshay777
    Donut Dec 14, 2016
    akshay777 , Dec 14, 2016 :
    me too but official updates are taking time and I think it's for good.
  16. DracoSura
    DracoSura , Dec 14, 2016 :
    Am currently downloading this for sideloading... Can those of you who installed it give some feedback?
    Thank you
  17. Wildvine
    Can you please confirm the full ROM file size?
  18. tmalkiew
  19. Crankyyy
    Already tried to install the oxygen recovery but my OP3 does only boot into recovery with the modified version...even after many reboots.
    Dont know what else i can try...
  20. MikeL333
    Froyo Dec 14, 2016
    MikeL333 , Dec 14, 2016 :
    Download the full zip and sideload via adb
    otto2 likes this.
