290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. Waka_Yama
    Ice Cream Sandwich Dec 14, 2016
    Waka_Yama , Dec 14, 2016 :
    try "default_password"; Likely it won't work... Try to flash the offical recovery via fastboot, saved my bottom today... ;)
    Try to flash the current Offical Recovery via fastboot. Download from here:
    Offical Download http://oneplusroms.s3.amazonaws.com/recovery_OBT7.img?AWSAccessKeyId=AKIAJ2SIWE7D3VMMGOEQ&Expires=1483694615&Signature=1Momnxm8gHWw03D401Oof5YxnE4=
  2. Neelavar Sumanth
    Gingerbread Dec 14, 2016
    Neelavar Sumanth , Dec 14, 2016 :
    @LesleySnijder , I've just updated to the Open Beta 9 and The DASH CHARGING. LED notification works fine
    also it clearly shows up as Dash Charging on the lockscreen
    proof that it works just fine for me
    otto2, Jole7 and Sahilkum like this.
  3. DracoSura
    DracoSura , Dec 14, 2016 :
    It's 1.32GB
  4. Kranthi prasad
    Cupcake Dec 14, 2016
    Kranthi prasad , Dec 14, 2016 :
    downloads are not working in play store,download manager is not working
    i had cleared the data and tried updated play store manually( apk) but no use
    vamshichaithanya likes this.
  5. Brammhojyoti Roy
    Brammhojyoti Roy , Dec 14, 2016 :
    THANKS one plus TEAM ... [e]1f603[/e][e]1f603[/e][e]1f603[/e] NAVER SEATTLE .. [e]1f44d[/e][e]1f44d[/e][e]1f44d[/e][e]1f44d[/e][e]1f44d[/e]
  6. Kranthi prasad
  7. halloarno
    halloarno , Dec 14, 2016 :
    Did you downloaded the rom from the website? Cause you cant flash the ota.zip through twrp.
  8. JasonMR
    Lollipop Dec 14, 2016
    JasonMR , Dec 14, 2016 :
    It's interesting that they haven't stated anything about having to contact CS for a special build this time, hopefully there will be no need to.
    This build feels as smooth as OB7 so far, but early yet to be sure.
  9. Wildvine
    Wildvine , Dec 14, 2016 :
    Thanks.. in OnePlus site its showing 1.42 GB..
  10. Wildvine
    I asked the same to @Tony L. ..But nothing from his side
  11. Rubensijperda
    Eclair Dec 14, 2016
    Rubensijperda , Dec 14, 2016 :
    Hi, I have the oxygenos open beta 8 installed on my OP3, and I found that it is encrypted by default, I didn't enable the decryption and I cant remove it either.
    When I enter twrp it will ask for an decryption key to update to Beta (9), but when I enter my password it says that it isn't the right key. I've already tried to reset the whole userdata via fastboot, which wiped my whole phone, but it didn't resolve it, the data was still encrypted.
    Please send me a reply if you have any idea of how to fix it. Thanks in advance!
  12. Crankyyy
    Crankyyy , Dec 14, 2016 :
    Thank you all! Had the wrong recovery version. Now i got to boot it! Btw i installed the Ota through the Open Beta 8 Os. Doesnt that work?
  13. deboer.rorik
    Donut Dec 14, 2016
    Sahilkum likes this.
  14. cselvaraj
    Froyo Dec 14, 2016
    cselvaraj , Dec 14, 2016 :
    Hi @Tony L. and oneplus developer team.
    Oneplus3 - The battery getting drained when the phone was idle.
    When i woke up every morning the mobile battery was reduced ~25%.
    Please fix this issue.
    Need more secure software.
    Thank you very much.
  15. F_Khải_Nguyễn_xakl
    Froyo Dec 14, 2016
  16. simonone
    Honeycomb Dec 14, 2016
    simonone , Dec 14, 2016 :
    It is blue for me
    otto2 likes this.
  17. JasonMR
    otto2 likes this.
  18. Asumos
    Asumos , Dec 14, 2016 :
    Here
  19. nitramcek
    nitramcek , Dec 14, 2016 :
    How can I delete that email that I wrote sometime back in my lockscreen? I can't find an option to change - remove it. Screenshot_20161214-192903_01.png
  20. astr0ng
    Eclair Dec 14, 2016
    astr0ng , Dec 14, 2016 :
    security then lock screen message
    otto2 and btjayakody like this.
