290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. Deactivated User
    Dec 14, 2016
  2. Wildvine
    Gingerbread Dec 14, 2016
  3. Ceasedd
    Marshmallow Dec 14, 2016
  4. Sahilk0369
    Honeycomb Dec 14, 2016
    Sahilk0369 , Dec 14, 2016 :
    Go to settings->security and fingerprint->lock screen message
  5. patriciodiazm
    Froyo Dec 14, 2016
  6. nitramcek
    Ice Cream Sandwich Dec 14, 2016
  7. nitramcek
    nitramcek , Dec 14, 2016 :
    Don't have that option. Must be some kind of bug. Didn't have it on beta 7 too.
  8. Deactivated User
    Dec 14, 2016
    otto2 and ghostofcain like this.
  9. simonone
    btjayakody and nitramcek like this.
  10. JasonMR
    Lollipop Dec 14, 2016
  11. simonone
    simonone , Dec 14, 2016 :
    In security and fingerprint, press the cog by Screen Lock, and all will be revealed
    nitramcek likes this.
  12. anandbibek
    anandbibek , Dec 14, 2016 :
    Anyone facing crash on opening Phone or Contacts app? It's crashing since I got a missed call. Logcat says can't access Contacts.db, but all permissions are set. It works fine if I dirty flash OB8, but not on OB9
  13. Wildvine
    Wildvine , Dec 14, 2016 :
    Touch the settings icon beside screen lock
  14. mmgherasim
    Froyo Dec 14, 2016
    mmgherasim , Dec 14, 2016 :
    Found the setting to disable sim cards, I didn't had it on OB8, must've been some kind of bug, but now I have this icon in status bar with disabled sim, will that be there as long as the sim is disabled ? :) I don't seem to find an option to hide it from status bar in Status bar settings. kind of annoying..
  15. dermot33
    dermot33 , Dec 14, 2016 :
    Theyre giving 3.5.4 to the 3T now.Bit worried that when it comes to the end of the month they'll give the 3t official nouget and the oneplus 3 will just be the guinea pig again waiting for official releases
    DracoSura likes this.
  16. rezwanur009
    Cupcake Dec 14, 2016
  17. Wildvine
    +1 the same was there on OB8
  18. F_Akshay_Mhatre_CHZr
    Eclair Dec 14, 2016
  19. nitramcek
  20. MarkLR
    Jelly Bean Dec 14, 2016
    MarkLR , Dec 14, 2016 :
    I just discovered that in this beta there is a hidden settings menu to enable auto rules for "do not disturb"!
    Go to the widget page on the home screen and add a settings widget, find the shortcut to do not disturb and you'll find it has auto rules!
    But it doesn't seem to work at all unfortunately.
    Hopefully they'll fix it for the stable version.
