290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. ediutomoputra
    Eclair Dec 15, 2016
    ediutomoputra , Dec 15, 2016 :
    Wait did LTE logo changed to 4G logo? Or is it depending on the cellular operators?
    Because for me i like to see LTE rather than 4G haha.
  2. Ninaad321
    Froyo Dec 15, 2016
    Ninaad321 , Dec 15, 2016 :
    Are the apps updating from playstore?
    apps are not even downloading.
    anyone facing this issue?
  3. sangsuryo
    Eclair Dec 15, 2016
    sangsuryo , Dec 15, 2016 :
    Attached battery performance.
    Some brief reviews
    Updated with leaked OB 9, 3 days ago.
    Generally are optimized and some bugs are ironed compared to OB 7
    Battery on days 3 is comparable with 3.2.8
    Notifications are still hit and miss like OB 7.
    Keep up for work team.
  4. Mohanty_tuhin
    Cupcake Dec 15, 2016
    Mohanty_tuhin , Dec 15, 2016 :
    I am having the same problem.
    Ninaad321 likes this.
  5. ajayclk
    Eclair Dec 15, 2016
    ajayclk , Dec 15, 2016 :
    In Open Beta 9 - the apps are not getting updated in play store... It shows "Downloading" forever... how to fix it... please help...
    Archies likes this.
  6. Shakib48
  7. tejakgp
    Honeycomb Dec 15, 2016
    tejakgp , Dec 15, 2016 :
    Guys anyone facing issue with phone going silent. I mean the slider position and all are normal. I go to sleep and wake up to a alarm graphic without sound. No call sound or notification(vibration works). Even if while changing the ring tone is silent. Music is working. I faced this issue with B8 first time and it's carried here. Restart helps but I am looking for a more reasonable solution.
    Mehran_Singh_Katoch likes this.
  8. ajayclk
    Eclair Dec 15, 2016
    play store apps are not getting updated in open beta 9.... how to fix it... please help...
  9. tejakgp
    Try turning on the hotspot. I used to have this issue but it's more resolved on its own after I serrated using hotspot.
  10. kunaltyagii
    Donut Dec 15, 2016
    kunaltyagii , Dec 15, 2016 :
    I think it might not be an issue with the open beta, I'm on 3.2.8 and sometime play store stops working for me too for last few days. Apps are not downloading and are stuck. Probably some issue with play store itself
    otto2 likes this.
  11. MrHowl
    MrHowl , Dec 15, 2016 :
    I'll be testing this out tomorrow. I won't lie, I'm stubborn and in the middle of a move so I flashed the zip through twrp, then had the encryption issue, factory reset, and now it's running.
    The only thing new that I see is the dm-verity at boot, which some research showed me is normal for someone running twrp. Little odd though, it never showed up on the stable builds from OP.
    Either way, it seems good so far. I'll let you guys know of any issues I encounter.
  12. ajayclk
    Eclair Dec 15, 2016
    I'm also facing same problem...
  13. SushanthMJoseph
    SushanthMJoseph , Dec 15, 2016 :
    Dear Tony, How will go to official naugat OTA from open beta 9 in future.. Please give me a reply. am I want to go to marshmallow for receive official naugat OTA from open beta 9???
  14. Strockus
  15. MrHowl
    It changes depending on Operator. When in my living room, mine likes to jump back and forth between 4G and LTE every fifteen minutes or so.
  16. mks693
    Eclair Dec 15, 2016
    mks693 , Dec 15, 2016 :
    On the op. Read carefully.
  17. rubenalamina
    Froyo Dec 15, 2016
    rubenalamina , Dec 15, 2016 :
    I was stuck in a TWRP bootloop after trying to update through the system OTA instead of flashing the full rom file. The description of my problem is in my previous post.
    For me, the solution was pretty simple actually. Since my data could be decrypted using my PIN while in TWRP, I made a manual backup of some folders, data, pictures, etc. I already had flashed the full rom file of Open Beta 9 in TWRP but the bootloop was still happening.
    To solve the bootloop, I flashed the stock recovery provided in the Downloads section of OnePlus Support website. I flashed it using fastboot (in TWTP tap Reboot - Bootloader), unplugged my phone from the PC and rebooted into recovery. It took like 5 minutes and the phone rebooted itself again automatically. I'm now in the system, the Open Beta 9 was applied and I didn't need to wipe anything.
  18. Archies
    Ice Cream Sandwich Dec 15, 2016
  19. r47z
    Gingerbread Dec 15, 2016
    Deactivated User and Archies like this.
  20. BestAkshay
    Donut Dec 15, 2016
    BestAkshay , Dec 15, 2016 :
    clear data of play store... reboot and everything will work again
