290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. snarfarlarkus
    Eclair Dec 15, 2016
    snarfarlarkus , Dec 15, 2016 :
    cleared all data in TWRP. Internal storage and everything besides usb otg. I reflashed OPB9 with debloater and it boots fine but as soon as I boot into TWRP it asks for that decrypt password... PLEASE HELP?!!!
  2. memys21
    Gingerbread Dec 15, 2016
    memys21 , Dec 15, 2016 :
    I did same as you, I am not facing any problem, Play Store works fine. Try to clear data and cache of Google Play Store, it might fix the problem.
    otto2 likes this.
  3. lucifer_angel
    lucifer_angel , Dec 15, 2016 :
  4. G_Kaushik_Iyer_qQLW
    Eclair Dec 15, 2016
    G_Kaushik_Iyer_qQLW , Dec 15, 2016 :
    Installed stable build and not experiencing the battery drain issue as I did with earlier beta 8.
    Desired stuff
    - mobile data on/off from the status bar. Right now it opens the mobile data menu.
    - doze button.. From alert slider or drop down
    Thanks,
    Kaushik Iyer
  5. amolsapre1
    Honeycomb Dec 15, 2016
    amolsapre1 , Dec 15, 2016 :
    Facing an issue with the alarm clock. Tried to set it for a short duration, it rang nice and loud. But I missed the 2 alarms i set for the morning. It never rang and also didnt give me a "missed alarm" notification.
    I also checked settings for new aggressive doze but could not find the alarm clock in there!
    Mehran_Singh_Katoch likes this.
  6. Nicolasgancia
    Cupcake Dec 15, 2016
  7. Manjulsharma807
    pbkurdekar likes this.
  8. rudeboyo
    Donut Dec 15, 2016
    rudeboyo , Dec 15, 2016 :
    aggressive doze still killing notification. if i set my chat app to not optimised, no notification kill. but it takes a lot of battery consumption. so i just turn off aggressive doze, and use normal doze :(
  9. ankitttt
  10. Mehran_Singh_Katoch
    Froyo Dec 15, 2016
    Mehran_Singh_Katoch , Dec 15, 2016 :
    I have been facing this problem since Official OTA version 3.2.8
  11. RONY JOHN
    RONY JOHN , Dec 15, 2016 :
    what ? ur sim card ? :D
  12. Amol Bichche.
    Amol Bichche. , Dec 15, 2016 :
    I have twrp 3.0.22 flashed by 3.o.28 recovery IMG.my phone is rooted tell me how to update open beta 9 using twrp.plz.
  13. DirkvanKollenburg
    DirkvanKollenburg , Dec 15, 2016 :
    Is there a way that my phone will show both the time where I am in the world and the time of my home time zone? I know my old Samsung S6edge showed it. Can a oneplus 3 do it to?
  14. Jyoti Prakash padhi
  15. shatadrusp
    shatadrusp , Dec 15, 2016 :
    Have you rooted it by flashing normal SuperSU? If yes, then try searching for SuperSU SR5 and flash this one instead.it should work absolutely fine.
    ghostofcain and Manjulsharma807 like this.
  16. HarryRag
    HarryRag , Dec 15, 2016 :
    Format data in twrp, all data on internal sd will be gone.
    On the other part, no debloater needed, just install opengapps pico and you'll be as near as stock as possible ;-)
  17. countthesaints
    Froyo Dec 15, 2016
    countthesaints , Dec 15, 2016 :
    Annnnnnd here we go again with the unnecessary comments and questions that have been made a million times.
    Anyway, I updated a little while ago, seems even more buttery smooth than before.
    Jrocci, otto2, Scherpenseel and 2 others like this.
  18. pushkarsoorma
    Froyo Dec 15, 2016
    pushkarsoorma , Dec 15, 2016 :
    Playstore not working. Cleared cache and data of google Playstore but still not working. Tested both on mobile data and wifi.
  19. pediocore
    Donut Dec 15, 2016
    pediocore , Dec 15, 2016 :
    I'm facing this issue as well.
    Artur4Life likes this.
  20. lucifer_angel
