290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. veerendra2406
    Cupcake Dec 15, 2016
  2. ghostofcain
    Marshmallow Dec 15, 2016
    ghostofcain , Dec 15, 2016 :
    Flash full rom package via TWRP not OTA.
    Come on, after less than 24 hours any comment on battery life is speculative at best.
    Yes
    That's what a factory reset does.
    No, /system remains ext4.
    Yes phone won't work, only /data should be f2fs
    Format, changing an intact partition is unlikely to be an option.
    Its all a matter of taste people have been clamouring for these to be reinstated, now they're clamouring to have them removed.
    Yes, as was beta 8.
    F_Emily_Liao_izHL, M3ntoR and gregb like this.
  3. nilesh555
    Eclair Dec 15, 2016
    nilesh555 , Dec 15, 2016 :
    have just checked my device is unlocked or lock.. In fastboot mode at bottom it shows with red color that DEVICE STATE - UNLOCKED that means my bootloader is unlocked??????
    Help me plz
  4. NigaDoge
  5. Bencherian
    Gingerbread Dec 15, 2016
    Bencherian , Dec 15, 2016 :
    Bluetooth Audio is not working ,can't play audio or video via Bluetooth speaker but it does support phone calls only
    Even if trying to click media sharing it doesn't work
  6. mmgherasim
    Froyo Dec 15, 2016
    mmgherasim , Dec 15, 2016 :
    YES ! It means your bootloader is unlocked. If you get this message (see attached) at startup, your bootloader is unlocked.
    nilesh555 likes this.
  7. JasonMR
    Lollipop Dec 15, 2016
    JasonMR , Dec 15, 2016 :
    In settings search for Home, it should be the first result "Home app"
  8. H. Gupta
    Honeycomb Dec 15, 2016
    H. Gupta , Dec 15, 2016 :
    I read it on the forum somewhere, factory reset doesn't wipe your internal storage, you have to do it exclusively.
  9. ghostofcain
  10. mmgherasim
    Froyo Dec 15, 2016
    You have the option to wipe or not the internal storage when you perform a factory reset from phone's OS.
  11. ruhela786
    Ice Cream Sandwich Dec 15, 2016
    ruhela786 , Dec 15, 2016 :
    These Antu tu and geekbench don't even matter until your phone is running smooth cupcake.
  12. nrjkmrdll
    Froyo Dec 15, 2016
    nrjkmrdll , Dec 15, 2016 :
    It's a feature bud, Nougat's feature
  13. Drako*
    Drako* , Dec 15, 2016 :
    hi everyone, new in the community.
    is this open beta compatible with the OnePlus 3t?
  14. nrjkmrdll
    Froyo Dec 15, 2016
    Nope
    ghostofcain and Drako* like this.
  15. Khadkapranav
    Eclair Dec 15, 2016
    Khadkapranav , Dec 15, 2016 :
    Flash the ROM, then flash SuperSU SR 5 then flash TWRP .28 again reboot to recovery.
    If it does not ask for password you are good to go...
  16. gagangk
    Donut Dec 15, 2016
    gagangk , Dec 15, 2016 :
    works fine in the car for me..calls as well as music...using poweramp for music..
  17. gagangk
    Donut Dec 15, 2016
    most of the applications are unable to access storage on my system..even screenshots are not getting created saying no storage although 40GB is free..clean flashed the rom..have root..anyone any help??
  18. jeevadon92
  19. mharis
    mharis , Dec 15, 2016 :
    Sure!
  20. mharis
    My post was about the 118 MB OTA.
    Did you flash the OTA package on CM? :O
