290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. kriniot6495
    Donut Dec 15, 2016
    kriniot6495 , Dec 15, 2016 :
    Thanks for reply.
    I know there are a lot of solutions rooting the phone but I think could be helpfully for everyone if OnePlus adds this option. It's not difficulty for them.
    Hope will adjust that algorithm.
    astralbee likes this.
  2. JasonMR
    Lollipop Dec 15, 2016
    JasonMR , Dec 15, 2016 :
    Have you got another launcher installed?
  3. ruhela786
    Ice Cream Sandwich Dec 15, 2016
    ruhela786 , Dec 15, 2016 :
    Of course you can, just sideload it dude.
    otto2 and Archies like this.
  4. ghostofcain
    Marshmallow Dec 15, 2016
    ghostofcain , Dec 15, 2016 :
    Use modified TWRP , link is in this thread official TWRP will not work.
  5. vnc95
    Gingerbread Dec 15, 2016
    vnc95 , Dec 15, 2016 :
    Thats exactly my problem 2
  6. ghostofcain
    Don't update binary using app, reflash sr5 via recovery.
  7. vnc95
    If its a google bug why doens't it show in a different dailer 3rd party dailer
  8. sandesh2007
    Eclair Dec 15, 2016
  9. MarkLR
    Jelly Bean Dec 15, 2016
    MarkLR , Dec 15, 2016 :
    I need someone of you to make a small test for me. You need to set your phone to Italian and see if you can use the search in the settings menu.
    Because on my phone, which is set to Italian, it doesn't work at all, but it works if I set the phone to English.
    It shouldn't take more than a couple of minutes to do this test.
  10. annoyingzlatan
    Froyo Dec 15, 2016
  11. MarkLR
    Are you sure? I have never had this issue on my previous phones. Never happened on any of my Sony phones or my Galaxy S4.
  12. kalander Shihab
    kalander Shihab , Dec 15, 2016 :
    To those who updated to beta 9 via OTA,
    do you get that annoying Android is updating/ optimizing apps screen that lasts forever?
  13. Sahilk0369
    Honeycomb Dec 15, 2016
    Sahilk0369 , Dec 15, 2016 :
    I think you can , but still check with others
  14. gregb
    gregb , Dec 15, 2016 :
    SETTINGS/APPS/COG wheel in the right top corner.....
    SETTINGS/WIRELESS AND NETWORK/emergency broadcasts
  15. r47z
    r47z , Dec 15, 2016 :
    nope. Didn't get that, just took longer to boot up without any optimizing app thing
  16. LinuxJedi
    Cupcake Dec 15, 2016
    LinuxJedi , Dec 15, 2016 :
    It is the different between GB and GiB. The first you divide by 1000, the second by 1024. This is also one reason why a computer reports a hard drive a bit smaller than the label.
    Sahilkum likes this.
  17. Chasticot
    Chasticot , Dec 15, 2016 :
    Hello,
    I can not receive or make calls, I configured the APN, the 4G data is OK, if I force in 2G I can receive and make calls ... if I try to send a call with the 4G, the network automatically switches to 3G and nothing.
    Does anyone have the same problem or solution?
  18. inffy
    KitKat Dec 15, 2016
    inffy , Dec 15, 2016 :
    Wipe your Google Play Store data and Google play services data and reboot
    Android N doesn't use that anymore, it does the optimising things in the background.
  19. kalander Shihab
    How longer?
    Did it take as much time as optimizing apps would take?
  20. kalander Shihab
    Isn't the seamless updates feature only for newer devices as it requires a second partition? Or am I missing something?
