290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. mmgherasim
    Froyo Dec 15, 2016
    mmgherasim , Dec 15, 2016 :
    Then, I believe, it's a bug present in the OS. It should search only in the contacts I set to be shown from the "Contacts do display" option. I hope Oneplus devs are reading this thread fully, even though there are many stupid and silly posts, and take this into consideration for a future update.
  2. stephenboyo
    KitKat Dec 15, 2016
    stephenboyo , Dec 15, 2016 :
    OK. I actually downloaded the full 1.3gb cb9 rom and dirty flashed it over CM14 in twrp. I think Cb8 was quite buggy, so this new build feels much better. I'm guessing cos cm14 is nougat there wasn't a problem dirty flashing cb9
  3. Victor_Peral
    Eclair Dec 15, 2016
    Victor_Peral , Dec 15, 2016 :
    Great job! No errors here!
    - Faster screen response.
    - Faster transitions in general.
    Only one thing. I have upgraded from v3.2.8 and I still have the same problem than with the previous version, it seems I notice some kind of cpu interruptions or littles lags. But as I said before, I was also suffering this with version 3.2.8. I'll try with a fabric default process...
    Sahilkum likes this.
  4. mharis
    Ice Cream Sandwich Dec 15, 2016
    mharis , Dec 15, 2016 :
    It's an interesting find. I would call it risky.
    How's the beta working for you? Any bugs yet? Apps downloading from playstore?
  5. L0cke
    Gingerbread Dec 15, 2016
    L0cke , Dec 15, 2016 :
    Everything working fine here and generally seems better than v8. Still would like some sort of scheduling options for the Night Mode though, but that's not a major issue.
    niclas.olsson likes this.
  6. Sahilk0369
    Honeycomb Dec 15, 2016
    Sahilk0369 , Dec 15, 2016 :
    Even I upgraded from 3.2.8, great performance overall
  7. Bencherian
    Bencherian , Dec 15, 2016 :
    Anyway to fix it ?
  8. McDriver
    Cupcake Dec 15, 2016
    McDriver , Dec 15, 2016 :
    Hi everyone.
    Do you know if GPS issues will be solved?
    Nowadays the signal get lost after a while.
    Keep on the good work.
    Regards!
  9. vnc95
    vnc95 , Dec 15, 2016 :
    Could you report it again in the bug list again? i already did it for beta 8
  10. stephenboyo
    KitKat Dec 15, 2016
    It's working very well. I thought I would check the speed/benchmarks as well and registered 161K on antu tu, which is super fast and I'm not even rooted or using any props, so that's great. Generally it feels much smoother than cb8 and apps are great and they've restored VoLTE. I only wish OP will improve the camera quality as it's not that great.
  11. danimartinez95
    danimartinez95 , Dec 15, 2016 :
    no the phone was more than usual in the power on animation. I think that's a Nougat function. you have ext4 or f2fs?
  12. sandesh2007
    Eclair Dec 15, 2016
    sandesh2007 , Dec 15, 2016 :
    I cleared cache and data from both. Even then it's not downloading/ updating
  13. _rishitvora_
    Froyo Dec 15, 2016
  14. brath23
    brath23 , Dec 15, 2016 :
    it happens the same in Spanish
  15. aschlag
    aschlag , Dec 15, 2016 :
    does anybody know why my twrp is encrypted after I updated via twrp and rebooted? I wanted to enter twrp after flashing beta 9 to root my phone.
    tried do decrypt it with my pattern and it doesn't work. I changed my phone password or removed it completly but without succsess.
    the only thing that works for me was formating userdata via fastboot and entering twrp bevor the first boot of the phone.
    did anyboby solve the password problem already?
    btw, i am really sorry for my english.
  16. EzhilrajOne
  17. mmgherasim
    Froyo Dec 15, 2016
  18. MarkLR
    Jelly Bean Dec 15, 2016
  19. Alecksander
    Alecksander , Dec 15, 2016 :
    U have ti delete all settings for launcher.
  20. Ceasedd
    Marshmallow Dec 15, 2016
    SimonRam, Robson, pa5t1s and 16 others like this.
