290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. Sun90
    Starting Point Expert Community Expert Dec 15, 2016
    Sun90 , Dec 15, 2016 :
    OTG is now Enabled default in Nougat.
    just connect the OTG device and u have the option to explore/eject as notification.
    otto2 likes this.
  2. inffy
    KitKat Dec 15, 2016
    inffy , Dec 15, 2016 :
    Nothing to do with seamless updates. This was considering the app optimising screen after a firmware upgrade which is not shown in Android N anymore because of the new app compiler included in N
    It should be enabled by default, no settings for it. So it should just work and you don't have to enable it
    otto2 and laurenzo87 like this.
  3. Deactivated User
    Dec 15, 2016
    SoniaB and Sahilkum like this.
  4. Alpha Mike Foxtrot
    KitKat Dec 15, 2016
    Alpha Mike Foxtrot , Dec 15, 2016 :
    Yeah. Nova. The only way you can get it to work is through the app.
  5. lunar_core
    Cupcake Dec 15, 2016
    lunar_core , Dec 15, 2016 :
    Hi guys,
    I just updated from the OB7 rooted with TWRP -28. Everything seems to work except root. SuperSU tells me that su binary is missing. I already tried to flash it again several times but didn't succeed. Doe anyone know how I can solve this?
  6. jatinkalra07
    Gingerbread Dec 15, 2016
  7. husen117
  8. Alpha Mike Foxtrot
    KitKat Dec 15, 2016
    T
    Thanks a ton!
    I wonder why did they make it so"not easy" to find.
  9. Alpha Mike Foxtrot
    KitKat Dec 15, 2016
    otto2 likes this.
  10. migton92
    migton92 , Dec 15, 2016 :
    Hi,
    I just install the Beta 9 on my One+ 3. The cellular data isn't working. I'm in France using Orange carrier. Am I the only one ?
  11. dermot33
    Ice Cream Sandwich Dec 15, 2016
    dermot33 , Dec 15, 2016 :
    I'm rocking dark mode with the glass green accent color but system apps like galary has a horrid pink/purple and dialer blue color
    .Is there any way to change these ?
  12. jatingada
    jatingada , Dec 15, 2016 :
    Thanks for your advice calvin. When OnePlus dosent care for their fans and customers, why should I take care of them. I trusted the brand and they are least bothered..
  13. Sahilk0369
    Honeycomb Dec 15, 2016
    Sahilk0369 , Dec 15, 2016 :
    Go to settings-display-screen calibration
  14. jatinkalra07
  15. jatinkalra07
    Sahilkum likes this.
  16. jeevadon92
    jeevadon92 , Dec 15, 2016 :
    turn on the battery saver mode and try
  17. pediocore
    Donut Dec 15, 2016
  18. G_BMWKante_vKip
    Donut Dec 15, 2016
    G_BMWKante_vKip , Dec 15, 2016 :
    I have elminated the doubled contacts. First I uninstall whatsapp. Contact's doubles were gone. Then I re-install whatsapp without given any permission. I made these permission when I have already installed the program. All contacts where shown once.
  19. SoniaB
    Nougat Head Moderator Dec 15, 2016
    SoniaB , Dec 15, 2016 :
    Sometimes a reboot is all you need.
    Great that it's working now for you!
  20. Scherpenseel
    KitKat Dec 15, 2016
    Scherpenseel , Dec 15, 2016 :
    Actually it's not that strange... 70% of IT requests are fixed by: "Have you tried turning it off and on again". People are just lazy often.
    brianjking, G_F._Anton_KFBw and otto2 like this.
