290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. Scherpenseel
    KitKat Dec 15, 2016
    Scherpenseel , Dec 15, 2016 :
    You can also uncheck whatsapp contacts in the contacts settings.
    MauroGimenez likes this.
  2. rahul2685
    Gingerbread Dec 15, 2016
  3. JasonMR
    Lollipop Dec 15, 2016
    JasonMR , Dec 15, 2016 :
    Odd, working for me:
  4. resporival
    Honeycomb Dec 15, 2016
  5. Sun90
    Starting Point Expert Community Expert Dec 15, 2016
    Sun90 , Dec 15, 2016 :
    Have u checked the APN settings
  6. Sun90
    No it's not Normal.
    check the advance setting in wifi and see if anything is turned on there.
  7. mmgherasim
    Froyo Dec 15, 2016
    mmgherasim , Dec 15, 2016 :
    Will try this now. I'll Be back with the result. thank you !
    Later edit: That didn't do the trick for me. The dialer still shows the contacts from other apps, like WhatsApp, when I search for one. Just to clarify this thing: it only shows when I search for a contact, not in contacts list. I have my contacts list set to show just Google contacts, but when I search one using T9 dial pad, that's when contacts show duplicates.
  8. F_Jason_Farah_Uypr
    Cupcake Dec 15, 2016
    F_Jason_Farah_Uypr , Dec 15, 2016 :
    having the exact same problem right now, no Data, SMS or calling working since the update to beta 9, I'm in Australia though with Amaysim.. Tried to switch to 3G/2G but nothing seems to be working at all.
    not sure what to do.
    might flash Beta 8 back :( was really enjoying Nougat.
  9. barkbill
    Froyo Dec 15, 2016
    barkbill , Dec 15, 2016 :
    For me it is fixed. I had this bug in all previous MM builds but now it's gone. I did a clean install by adb sideload with internal memory wipe too.
  10. giatros
    Donut Dec 15, 2016
  11. Tony L.
    Tony L. , Dec 15, 2016 :
    Unfortunately if you want to go back to MM builds, you'll have to contact our CS support.
    otto2 likes this.
  12. mharis
    Ice Cream Sandwich Dec 15, 2016
    mharis , Dec 15, 2016 :
    Did you update through OTA?
  13. Rakesh_j3010
    Donut Dec 15, 2016
    Rakesh_j3010 , Dec 15, 2016 :
    Having a problem in the beta while playing games like clash royale the sound is playing in the background unless u clear the app in the background has anyone faced it
  14. ghostofcain
    Marshmallow Dec 15, 2016
    ghostofcain , Dec 15, 2016 :
    I just flashed sr5 via TWRP and all worked for me.
  15. gourab999
  16. mmgherasim
    Froyo Dec 15, 2016
    I already said that I had my option set to only show contacts from Google account, so what you're saying does not apply here. See screenshots attached.
    %eLIRXR8QQucHDlKcZZZfw_thumb_4.jpg 9%hWqbWMTuqnzUHu02Mg+Q_thumb_3.jpg KiGkL1UdRo+JF6w6WBLNRQ_thumb_2.jpg
  17. jatinkalra07
    jatinkalra07 , Dec 15, 2016 :
    yes
  18. Hari5679
  19. asihrocks23
    asihrocks23 , Dec 15, 2016 :
    I am facing the same issue on OB9. This does not happen when I go to the contacts app and search but rather happens on the dialer app only. Any idea on how to fix this?
  20. lucifer_angel
