290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. migton92
    Cupcake Dec 15, 2016
    migton92 , Dec 15, 2016 :
    Hi,
    Yes and the configuration seem to be ok !
  2. G_Espen_Nordheim_Karlsen
  3. Shubhamwaghulde1294
  4. yofellas
    Gingerbread Dec 15, 2016
    yofellas , Dec 15, 2016 :
    i have noticed some overheating issues with this update usking dash charger and also while not charging.... also the notification bar donot comes incthe middle when the DPI is changed... and the phone is in landscape mode.
  5. hatprab
    hatprab , Dec 15, 2016 :
    After rooting playstore not working
    i flashed beta 9 from beta 8 using TWRP
    help
  6. JoaoLetelier
    Froyo Dec 15, 2016
  7. tsiftsism
    Donut Dec 15, 2016
    tsiftsism , Dec 15, 2016 :
    Ι have no such issues while playing games (Dominations, Candy Crush Soda, Alto, Limbo and Never Alone).
    Sahilkum and Rakesh_j3010 like this.
  8. JoaoLetelier
    Froyo Dec 15, 2016
    JoaoLetelier , Dec 15, 2016 :
    When they say that downgrading back to M will format your device, do they mean the internal memory, or just data.
    I ask in case I don't like the ROM and want to switch back to M or a custom ROM.
  9. ThePlainGamer
    Honeycomb Dec 15, 2016
    ThePlainGamer , Dec 15, 2016 :
    I want to flash beta 9 but the problem is that the phone is encrypted by default? so can you just use adb sideload then when the phone is encrypted?
  10. mharis
    Ice Cream Sandwich Dec 15, 2016
    mharis , Dec 15, 2016 :
    It's a SwiftKey theme. (Amethyst)
    No it doesn't adapt to the current app.. I wish SwiftKey could implement something of that sort though :)
    JoaoLetelier likes this.
  11. migton92
    Well ! I check the configuration of the APN. The APN name of orange.fr is wrong
  12. F_Jason_Farah_Uypr
    F_Jason_Farah_Uypr , Dec 15, 2016 :
    I updated through ota and it failed... then I flashed it through TWRP, why?
  13. DrVikTroll
    DrVikTroll , Dec 15, 2016 :
    Because OTA only works with stock recovery, unfortunately.
    If you download the full update package and flash it, it will restore the stock recovery and the OTA updates will work fine.
  14. G_cosimo_torcello_yXzL
  15. mharis
    I think the no network issue is related to flashing OTA through TWRP.
    I'd rather flash the whole firmware using modified TWRP.. superstable
  16. F_Jason_Farah_Uypr
  17. ghostofcain
    Marshmallow Dec 15, 2016
    ghostofcain , Dec 15, 2016 :
    December here in the UK doesn't end for another 17 days ,so we aren't even half way through. anyway no one will give you an exact date, personsally I wouldn't bet on it arriving before the 31st.
    otto2 likes this.
  18. nilesh555
    Eclair Dec 15, 2016
    nilesh555 , Dec 15, 2016 :
    Showing at startup bootloader is unlocked can't be trusted
    wtf is this cant be trusted
  19. Wildvine
    Wildvine , Dec 15, 2016 :
    Thanks for the confirmation :)
  20. vriesdejoop
    vriesdejoop , Dec 15, 2016 :
    Checked it, I can search in Italian..
    Sahilkum likes this.
