290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. Wildvine
    Gingerbread Dec 15, 2016
    Wildvine , Dec 15, 2016 :
    It will format the drive partition.. so you have to take backup
  2. Auristic
    KitKat Dec 15, 2016
    Auristic , Dec 15, 2016 :
    Maybe to repel ex Gs like you, "bro"! ;)
  3. mharis
    Ice Cream Sandwich Dec 15, 2016
  4. G_cosimo_torcello_yXzL
    Cupcake Dec 15, 2016
  5. MarkLR
    Jelly Bean Dec 15, 2016
  6. F_Jason_Farah_Uypr
    F_Jason_Farah_Uypr , Dec 15, 2016 :
    Fixed it! I just reflashed the same zip and it worked! Phew & Woohoo, Thanks :D
    now I have a feeling Root is the cause of this, Going to flash SuperSu and see how I go
    mharis likes this.
  7. DrVikTroll
    DrVikTroll , Dec 15, 2016 :
    Roaming means no data connection when abroad.
  8. Desejmon
  9. G_cosimo_torcello_yXzL
    G_cosimo_torcello_yXzL , Dec 15, 2016 :
    yes .....but even if you have a manager like h3g leaning on other networks. in Italy there are agreements between TIM and H3G. the data connection does not pay you if you are under h3g coverage .... otherwise you pay
  10. F_Facu_Yavicoli_gVck
    Eclair Dec 15, 2016
  11. simonone
    Honeycomb Dec 15, 2016
    simonone , Dec 15, 2016 :
    "On the verge of ending" = Exactly half way through?
    These excellent Nougat betas suggest everything is going according to plan. Try to restrain your curiosity, or join us in enjoying the beta builds.
  12. XhetriB
    XhetriB , Dec 15, 2016 :
    Hi All,
    Currently i'm using 3.5.5 & i received update for open Beta 9. I downloaded that but when i'm installing it says "Installation Fail." Please help..
  13. Alpha Mike Foxtrot
    KitKat Dec 15, 2016
    Auristic likes this.
  14. Alpha Mike Foxtrot
    KitKat Dec 15, 2016
  15. F_Jason_Farah_Uypr
    so it turns out that flashing root is the cause for my "No service" message, any idea what I can do or what the right supersu flash zip file is?
  16. ace_atishay
    Donut Dec 15, 2016
    ace_atishay , Dec 15, 2016 :
    I don't whether it's after I updated my phone this morning or not but I can't download/update any app on Play Store. It just keeps on showing downloading and nothing happens. I tried data as well as wifi. I know Nougat doesn't allow to download anything from Play Store on data ovee Roaming but local data and wifi aren't working as well. Help please.
  17. Alpha Mike Foxtrot
    KitKat Dec 15, 2016
    Alpha Mike Foxtrot , Dec 15, 2016 :
    No. And if it is, you can change the animation speed within the launcher itself.
  18. Alpha Mike Foxtrot
    KitKat Dec 15, 2016
    I don't mean to offend you, but isn't it supposed to be lucifer "angel"?
    Just curious.
    lmilford, PAVAN BP and tedulus like this.
  19. vriesdejoop
    vriesdejoop , Dec 15, 2016 :
    Did you do a clean flash?, I "dirty" flashed over leaked beta 9, that was dirty flashed over beta 8. Beta 8 was clean flashed. Perhaps something missing after clean flash?
  20. ibrahim syed
    ibrahim syed , Dec 15, 2016 :
    lol OnePlus should close. Rip offs
