290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. ibrahim syed
    Gingerbread Dec 15, 2016
    ibrahim syed , Dec 15, 2016 :
    these shouldn't be beta in the first place
  2. F_Khải_Nguyễn_xakl
    Froyo Dec 15, 2016
    F_Khải_Nguyễn_xakl , Dec 15, 2016 :
    I did, I post the bug here to let people know that it exists, since they dont show us what bugs has been reported.
  3. ibrahim syed
    trust me actual update won't be stable after all these betas... i can bet you
  4. BeelzeBu
    Froyo Dec 15, 2016
    BeelzeBu , Dec 15, 2016 :
    You need to use SR5, I'm using it without problem
  5. MarkLR
    Jelly Bean Dec 15, 2016
    MarkLR , Dec 15, 2016 :
    Dirty flash over Beta 8, which was clean flashed instead. I'm going to try and mess around and see if I can fix it somehow. Maybe cleaning cache, data or some stuff like that. Does anyone know if I delete cache and data for the main settings apk, will I lose all my settings or something? I've never done this to the main settings app and I wouldn't really want to lose all my settings or something...
  6. PAVAN BP
    Honeycomb Dec 15, 2016
    PAVAN BP , Dec 15, 2016 :
    haha
  7. preatorious3010
  8. Hari5679
    Cupcake Dec 15, 2016
  9. MarkLR
    By the way, I think the ROM pretty much covers all the basis (other than the crappy stock music app), every built in feature is useful and well made. I think when it comes to additional features, they should implement some way to record the screen to video (I had this feature on my Sony Z3 and it was ridiculously useful sometimes), and a camera mode that allows scanning QR codes. Other than that I think we're good with non-stock features.
    As for missing stock features, we only need Do Not Disturb (I know additional apps can do it but I think such a feature should be built in for maximum reliability and security). Since the feature has been added back to the rom, even though it's hidden and doesn't work, they're probably working on it.
  10. ThePlainGamer
    ThePlainGamer , Dec 15, 2016 :
    why are you even here then in the first place?
    ghostofcain and Scherpenseel like this.
  11. AcmE85
    Ice Cream Sandwich Dec 15, 2016
    AcmE85 , Dec 15, 2016 :
    I am using the stock OOS camera with google's screen search feature for that. Works good so far.
    It even recognizes some known logos.
  12. brath23
    brath23 , Dec 15, 2016 :
    I cleared Settings app data and now it works....Good idea, I didn't think about clearing app data.
    Yo have to go to Apps in settings, check the Show system apps in the 3 dot menu and look for the app....In Spanish is called "Ajustes"
  13. Hitesh_Gupta
    Hitesh_Gupta , Dec 15, 2016 :
    Hello Everyone,
    I am planning to install Open Beta 9 on my OP3 device. Currently, I am on OP3 stable build 3.2.8 with stock recovery unrooted.
    I understand that I will need ADB drivers installation to sideload this ROM to my phone. Also, I want to convert the partition(s) to F2FS.
    Just an update here...my laptop is running Windows 10-64 bit. Most of the information i find for ADB drivers installation is only for older Windows versions.
    Can someone guide me to the process of installing ADB drivers, changing the partition to F2FS & flashing open beta 9 all with the stock recovery please?
    Thanks in advance guys.
  14. DrVikTroll
    DrVikTroll , Dec 15, 2016 :
    In that case you need a different option called 'national roaming'
  15. jayasurya29
  16. F_Andrea_Ippolito_ZsRS
  17. Cmour88
    Cmour88 , Dec 15, 2016 :
    I, after the installation a was unable to access to my messages and unable to send or receive, anyone with the same problem?
  18. raja.d
    raja.d , Dec 15, 2016 :
    take a backup and clear your data and cache from recovery
  19. Deepak NR
  20. MikeL333
    Froyo Dec 15, 2016
    MikeL333 , Dec 15, 2016 :
    When I say 'Full zip', I don't mean the OTA zip. You have to download the entire ROM (1.4GB) and sideload it via adb.
