290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. mharis
    Ice Cream Sandwich Dec 14, 2016
    mharis , Dec 14, 2016 :
    #81
  2. dkumar.ism
    Cupcake Dec 14, 2016
    #82
  3. Wildvine
    Gingerbread Dec 14, 2016
    Wildvine , Dec 14, 2016 :
    Really missing the data traffic notification feature while downloading/updating stuffs
    #83
    SatriaPerdana, Fakunofx and mharis like this.
  4. AcmE85
    AcmE85 , Dec 14, 2016 :
    You can't read, that's all. Unfortunately you are not the only one so this thread will be flooded shortly
    You were asking if this version is any different to the previous leak. Already mentioned this before:
    edit: you know what, I probably overreacted a little. Sorry about that. Too tired....
    #84
  5. ExtremeNuker
    ExtremeNuker , Dec 14, 2016 :
    What font do you use?
    #85
  6. EzhilrajOne
    #86
  7. mharis
    Can you confirm that the battery percentage font size has been increased on the Statusbar.. if you were using it previously.
    #87
  8. guruprasad99
    guruprasad99 , Dec 14, 2016 :
    in my I am not getting OTA update today
    #88
  9. mharis
    #89
  10. Wildvine
    +1 Its really larger than other fonts in statusbar
    #90
  11. Sahilk0369
    Honeycomb Dec 14, 2016
    Sahilk0369 , Dec 14, 2016 :
    Report it using the link that is present in the first post by Tony
    #91
  12. sen2015
    sen2015 , Dec 14, 2016 :
    Open Beta 9 installed. Thanks Oneplus
    #92
  13. F_Yves_Fleury_kvlR
    #93
  14. 4sheesh
    #94
  15. OnePlusGerrie
    #95
    Crystal Z. likes this.
  16. Droos
    Eclair Dec 14, 2016
    Droos , Dec 14, 2016 :
    i should read the manual first. Tried to install the OTA trough beta 8 with modded TWRP SR5, but it will only boot into recovery :)
    #96
    gregb likes this.
  17. MarkLR
    Jelly Bean Dec 14, 2016
    MarkLR , Dec 14, 2016 :
    Found a bug already, searching the settings menu brings up no results other than the main settings elements (such as wifi, bluetooth, etc).
    #97
    Sahilkum likes this.
  18. Nitheesh Reddy M
    #98
  19. amolsapre1
    amolsapre1 , Dec 14, 2016 :
    Live Wallpapers are now working perfectly on the lockscreen. In beta 8 it used to show a black screen when a live wallpaper was set. Thanks oneplus for fixing this!
    #99
  20. seganaUK
    seganaUK , Dec 14, 2016 :
    No, no we don't. The "idea/concept" of it is fine, but the practicality...awful. How many contacts in your phone have a high resolution image to be used for that UI?
    Whats your default for contacts with no image? A silhouette? A coloured/gradient background?
    I'd be willing to bet for most calls you'd get either the default 'no image' UI or a horribly pixelated image due to it being stretched to fit the UI.
    Don't mean to come off as harsh on your design; as at the end of the day rather than just complain you've at least attempted to demonstrate an alternative, but you need to consider the real-life experience a user would have. We all like to design for the perfect scenario and there's nothing wrong with that, but there's soooo much to consider when it comes to UI/UX, not just what "looks good" in one instance.
