290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. rarog
    Lollipop Assistant Head Moderator Dec 15, 2016
    rarog , Dec 15, 2016 :
    This means, that theoretically somebody would be able to flash something on your system to get your data Or install something secretly. Because with locked bootloader and OOS this is much harder to do, because if you had clean and unmanipulated device, most tries to get to your system or data would result in a factory reset.
    otto2 likes this.
  2. lucifer_angel
    Gingerbread Dec 15, 2016
    lucifer_angel , Dec 15, 2016 :
    Ohh thanks..:p
    I didn't notice that mistake.:D
    Auristic likes this.
  3. Cmour88
    Cupcake Dec 15, 2016
    Cmour88 , Dec 15, 2016 :
    I can't backup the messages, do you recommend any app to backup, I try use the SMS backup and recover
  4. Deactivated User
    Dec 15, 2016
  5. rknaiduk
  6. AcmE85
    Ice Cream Sandwich Dec 15, 2016
    AcmE85 , Dec 15, 2016 :
    I found out that using a modified TWRP depends on the used filesystem.
    There are versions which will ONLY decrypt your DATA partition on EXT4 and some which only work on F2FS.
    If you are encrypted and still using EXT4 you have to use 3.0.2-1.25.
    https://www.dropbox.com/s/x9tahfjcvvsi3z1/twrp-3.0.2-1.25-oneplus3.img?dl=0
    If you are using F2FS you have to use the latest 3.0.2-1.28.
    I discovered this a while ago when switching to F2FS.
    3.0.2-1.25 used to work without issues on my devcie, but after reformating the storage from EXT4 to F2FS it would not accept my password anymore. After flashing 3.0.2-1.28 the password was accepted again.
    Bigbabba likes this.
  7. mmgherasim
    Froyo Dec 15, 2016
    mmgherasim , Dec 15, 2016 :
    Most likely, yes. But you guys have to stop asking this.. for you will only make this thread longer and harder for devs to read actual important bugs related things so they can work on the stable version. Nobody knows the exact date. Just have patience.
    ghostofcain likes this.
  8. ghostofcain
    Marshmallow Dec 15, 2016
    ghostofcain , Dec 15, 2016 :
    Sorry that's how software development works, I look forward to your new model.
    The beta already is stable.
    So they say, although it's also said that each asking delays the release by a day so early March by this thread alone.
    otto2 and mmgherasim like this.
  9. Topper_Gas
    Jelly Bean Dec 15, 2016
    Topper_Gas , Dec 15, 2016 :
    If you've stayed with OTA's this long hadn't you now might as well wait and see if the Nougat OTA arrives this month, rather than attempt to do something you not really sure how to do with your phone?
    Once you move to the Beta it'll be hassle getting to the OTA's should you want to in the future.
    If you do want to change the OP website/this forum/YouTube really tells you all you need to know.
  10. sandesh2007
    Eclair Dec 15, 2016
    sandesh2007 , Dec 15, 2016 :
    I am not able to download/update apps thru Play Store. Kindly Help.
    Note: I have cleared cache and data of play store and play services.
  11. vriesdejoop
    vriesdejoop , Dec 15, 2016 :
    Make normal screen shot (Power + button down) then press the thirt button on the bottom next to the carbidge bin... looks like :
    ____
    ____
    HarryRag likes this.
  12. ghostofcain
    .28 is what I've been rocking since CB 5,only been on f2fs since beta 8. Never had a problem restoring builds.
  13. chetannd
    Eclair Dec 15, 2016
    chetannd , Dec 15, 2016 :
    turn on battery saver... Magic:)
  14. ArKay74
  15. AcmE85
    Beta 5 has been released on 2016-10-17.
    TWRP .28 has been released on 2016-11-29.
    I am preeeeetty sure you are wrong.
    Nothing to add here I guess ;)
  16. ArKay74
    ArKay74 , Dec 15, 2016 :
    Check Status Bar settings, percentage is an extra.
  17. Jus Wil
    Jus Wil , Dec 15, 2016 :
    Hey All
    I am unable to see google cards/Feeds. It says its not available in my country. But on beta 8 it worked perfectly. Any way to fix this?
  18. Yugendher_Vinayak_98
  19. Hitesh_Gupta
    Hitesh_Gupta , Dec 15, 2016 :
    Thanks for your reply man. I intend to stay with BETA's going forward so that is fine with me. I have managed to install USB drivers & ADB on my laptop. However, the only query I now have is how to convert the partition(s) to F2FS & if this is to be done only for a specific partitions. Can you help me with this information?
  20. MarkLR
    MarkLR , Dec 15, 2016 :
    Cool, indeed this could be a solution. Unfortunately this requires Google Now which to me never provided any useful info and increased battery and data consumption. I'd prefer a built in lightweight solution to scan codes. I use a small app called QR Code Reader from the play store but I would really prefer to use a stock app for this.
