290
OxygenOS Open Beta 9 (N) for OnePlus 3
  1. priyabrata.pinku
    Froyo Dec 18, 2016
  2. Antoine Vdb
    KitKat Dec 18, 2016
  3. Dalibor Hon
    Cupcake Dec 18, 2016
    Dalibor Hon , Dec 18, 2016 :
    Oh I thought that something bugs out, but it makes sense to have this like it is because of that slider.
  4. AcmE85
    Ice Cream Sandwich Dec 18, 2016
  5. mmgherasim
    Froyo Dec 18, 2016
    mmgherasim , Dec 18, 2016 :
    I have the same issue with dark theme enabled. I lost 17% overnight whereas with default theme I only lost 6%, and I picked it up now with 51% and as I type now after 10 min of using it, I'm at 45% already. Please try using default theme and let me know if you see improvement. I left dark theme enabled so I can convince myself this is indeed a cause for the faster draining of the battery. I will report this as a bug and I suggest you do the same.
  6. bassgenerator
    Gingerbread Dec 18, 2016
  7. Jac_Q
    Jac_Q , Dec 18, 2016 :
    I don't want to question your request, it's most probably useful to you.
    But calling a fingerprint sensor insecure because you sleep and have people around you that then use your finger?
    It's like saying that your door lock is insecure because you leave your keys out in the open.
    Btw.: My screen turns off fine after double tapping.
  8. Sun90
    Starting Point Expert Community Expert Dec 18, 2016
    Sun90 , Dec 18, 2016 :
    it's already there in CB 9, just check under buttons settings.
  9. mmgherasim
    Froyo Dec 18, 2016
  10. G_Karol_Przestrzelski_aW
    Dusten_Barker likes this.
  11. NeelavarSumanth
    NeelavarSumanth , Dec 18, 2016 :
    ******* battery life , been two on the OB9 and my battery life sucks as hell.
    seriously , need some support over this Problem. Hope we all get The Stable Noughat Build too(with this problem kicked out sooner)
  12. Paraskhavadia
    Eclair Dec 18, 2016
  13. Nitish Singhal
    Eclair Dec 18, 2016
    Nitish Singhal , Dec 18, 2016 :
    what are the other apps to make a Network video call? (not using Internet like Skype, Hangout..)
  14. Paraskhavadia
    Eclair Dec 18, 2016
    Paraskhavadia , Dec 18, 2016 :
    default mode is running fine
  15. OBELISK.Duy
    Eclair Dec 18, 2016
  16. mmgherasim
    Froyo Dec 18, 2016
    We need to report every issue we encounter, as they won't fix itself. We can't just wait for the official update and hope all problems are solved. Developers need our feedback. You should report anything you find wrong on your device if you run OB9.
    ruhela786, otto2 and AcmE85 like this.
  17. mtbgus
    Honeycomb Dec 18, 2016
    mtbgus , Dec 18, 2016 :
    Seriously? All that screenshot tells us is that at 93% you're played Clan of Clans and android is calculating that if you keep playing at the same rate you'll be able to play for 3 hours! Not bad amount of time for a phone to be working with a game and a screen on the whole time. Obviously if you then turn the phone screen off and let it rest, maybe do other thing than play the game the battery chart with change to more than 3 hours left!
    ruhela786 and inffy like this.
  18. Naee
    The Lab - OnePlus 5T Reviewer Dec 18, 2016
    Naee , Dec 18, 2016 :
    What icon pack are you using?
  19. 50960
    50960 , Dec 18, 2016 :
    Yes, you got a point there.
  20. Superstar005
    Superstar005 , Dec 18, 2016 :
    Am I the only one who have issue with data usage? Since 3.2.9 I can't use my data when Wi-Fi turns off!
