112
OxygenOS tips for the OnePlus 7 Pro
  1. Texasaggie1
    US Brand Ambassador Jul 29, 2019
    Schafer likes this.
  2. I1562810387173
    Cupcake Jul 29, 2019
    I1562810387173 , Jul 29, 2019 :
    I wanna use other themes but here is only three options of themes plz tell me how can download new themes
  3. jjvoliver
    Froyo Jul 29, 2019
  4. PankuR7
    PankuR7 , Jul 29, 2019 :
    Parallel app feature is not working for all the app. its working only for social media apps. why OxygenOs using this filter?
  5. Hitman424
    Gingerbread Jul 29, 2019
    Hitman424 , Jul 29, 2019 :
    agreed.
    TGardner likes this.
  6. Z1564379659247
    Z1564379659247 , Jul 29, 2019 :
    I am unable to answer the WhatsApp call through my car's Bluetooth. can you please advise if any settings need changing.
  7. ashunaresh
  8. HardGamer151
    Cupcake Jul 30, 2019
  9. B1531161488305
    Donut Jul 30, 2019
  10. TGardner
    Gingerbread Jul 30, 2019
    TGardner , Jul 30, 2019 :
    You're speaking in code. Try again.
  11. Evanspy
    Froyo Jul 30, 2019
    Evanspy , Jul 30, 2019 :
    I really want something to make the background of notifications black or at least grey to match everything else.
  12. SunnyAustin81065
  13. Vady
    Vady , Jul 30, 2019 :
    damn no one told me you can disable status bar icons even when I asked, really needed that. But what's missing is being able to disable a specific sim's icon.
  14. hjgwynne
    hjgwynne , Jul 30, 2019 :
    Would love to be able to change the notification volume separately from ringer volume.
    JonuRee likes this.
  15. tri_venkat
    tri_venkat , Jul 30, 2019 :
    For oneplus 7 pro can we charge and use the phone at a same time is there any issue for battery or for phone health
  16. tri_venkat
    Hi while using vibration option in ONE PLUS 7 PRO mm-mm options only working and other vibration mode like dz-da are not working. is it hard ware issue or software issue. any solution for this issue
  17. tri_venkat
    yeah I can't also able to use after the update
  18. IkeIke
    Eclair Jul 30, 2019
    IkeIke , Jul 30, 2019 :
    Hi All. Wouldn't it be great if you could move the Shot on OnePlus watermark to other areas of the picture instead of just the lower left corner of picture?
    OnePlus, please consider this simple but important aspect of customizing the camera.
    Best regards.
    Ike.
    12gbRom256gbRamOP7Pro.
    Nigeria, West Africa.
  19. IkeIke
    Eclair Jul 30, 2019
    I'd suggest you download the full update package and install. The incremental update package also gave me a couple of issues but all resolved when I applied this method.
  20. N1558823666616
    N1558823666616 , Jul 30, 2019 :
    When using WeChat or other chatting Apps,it is necessary to have Quick response funktion.With that It will be much more convinient.
