2
OxygenOS v2.2.0: Is it good?
  1. MasterPoiuy
    Gingerbread Dec 21, 2015
    MasterPoiuy , Dec 21, 2015 :
    Last time I updated mine quickly without prior reviews and suffered unusual battery drain. This time I want to make sure everything is good. What do you say, bros?
    Markawhite and Dr.TicTacToe like this.
  2. sfomin
    Nougat Dec 21, 2015
  3. sumedhgg
    sumedhgg , Dec 21, 2015 :
    Color balance or screen temperature is not working (on my phone at least). It stays warm (yellowish) no matter what the position of the slider is.
    Anyone else facing this issue?
  4. sanchitd5
    Honeycomb Dec 21, 2015
    sanchitd5 , Dec 21, 2015 :
    on stock kernel it works.
    on boeflla kernel it doesn't
    can't say about ak
    gamsurslicki likes this.
  5. souvikdas95
    Ice Cream Sandwich Dec 21, 2015
    souvikdas95 , Dec 21, 2015 :
    so clear that you can't even differentiate the changes...
  6. mido25
    mido25 , Dec 21, 2015 :
    I am waiting for users to report bugs. Not making any mistake like last time.
    nh_opu and khaniq like this.
  7. aneesimran
    aneesimran , Dec 21, 2015 :
    So far it seems that the battery has improved and performance is a lot better and smoother while scrolling then oxygen OS 2.1 (haven't tried stock kernel since been using boeffla).
    aenews likes this.
  8. jamesylynch
    Froyo Dec 21, 2015
    jamesylynch , Dec 21, 2015 :
    For a couple minutes after update, the phone was in general very laggy. Don't know if that is normal or not. Vellamo tests are sub OPO standard as well :(
  9. sumedhgg
    I am on stock kernel. No root. Just flashed the ota 2.2.0 zip.
    After a reboot, just once, the color balance slider changes the temperature during preview only but fails to apply it. Later just doesn't respond to any change.
    Any solutions?
    DavidRoselman likes this.
  10. souvikdas95
    then you probably won't notice much of any change. boeffla currently uses stock 2.1.2 as base kernel for its modifications. once you flash it, you basically flash the stock 2.1.2 kernel along with it.
  11. sanchitd5
    checked mine same happening here..
    sumedhgg likes this.
  12. joesweeney413
    Jelly Bean Dec 21, 2015
    nitin_g3 likes this.
  13. Akshat2793
    Akshat2793 , Dec 21, 2015 :
    Ak kernel is also not supported. It supports only Oxygen OS 2.1.2 as of now.
  14. Bartrijg
    Froyo Dec 21, 2015
    Bartrijg , Dec 21, 2015 :
    Well the holiday wallpapers are nice :p
    And i do like the screen temperature feature right in the quick settings.
    Since i didn't encounter too much bugs with the previous version, I can't say they solved a lot of issues for me. But at least is doesn't run buggier, so in general i can say that it actually is any good :)
    BassVity likes this.
  15. anupritaisno1
    KitKat Dec 21, 2015
    anupritaisno1 , Dec 21, 2015 :
    ak kernel was abandoned
  16. Akshat2793
    Yeah i know, you told me earlier in another thread.
    Bharath HT likes this.
  17. magnamentis
    magnamentis , Dec 21, 2015 :
    then don't post like if it wouldn't be abandoned, easy as that ?
    DanteGR likes this.
  18. vinko1950
    Eclair Dec 21, 2015
  19. Altatron
    Altatron , Dec 21, 2015 :
    How long does the phone take to boot up? Feels like I'm stuck in a boot loop. I dirty flashed it. It's been 15 minutes.
  20. Clement Louis
    Froyo Dec 21, 2015
    akbasu777 likes this.
