package installer problem
  1. B1536921498231
    Cupcake May 18, 2021
    B1536921498231 , May 18, 2021 :
    so my package installer is not working now any help ?
    it sends me this message " can't open file " so apparently I can't open any apks no more
    can anyone help me fixs the package installer
  2. Caomhin
    OnePlus 9 Series Expert Community Expert May 19, 2021
    Caomhin , via OnePlus 9 Pro , May 19, 2021 :
    Reset the App permissions, it may be that an app or apps or something connected is causing the issue.
    Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    This will not delete your apps data but you will have to provide permissions for all your Apps again.
    Check if this can help.
    Bobbie63 and Aaron2017 like this.
  3. B1536921498231
    Cupcake May 20, 2021
    B1536921498231 , May 20, 2021 :
    tried but did not work [e]1f625[/e]
  4. Caomhin
    OnePlus 9 Series Expert Community Expert May 20, 2021
    Caomhin , via OnePlus 9 Pro , May 20, 2021 :
    Go into settings, search for package installer, Clear the App info Cache and App info Storage as well.
    Restart the phone and see if it will open the apks. If not. Search for Package installer again. This time in App info click on Advanced, Open by default and Clear Defaults.
    Again restart the phone and check if this fixes the issue.
    Bobbie63 likes this.
  5. B1536921498231
    tried the first one didn't work
    about the second one I entered but I can't do anything it doesn't give me the ability to change or reset
    Caoimhín likes this.
  6. Caomhin
    So that's the problem, the package installer seems to be corrupted in some way.
    Try this Apk Installer from the Playstore.
    https://play.google.com/store/apps/details?id=com.apkinstaller.ApkInstaller
    Once installed click on the Apk you want to install. Check if you get a choice of Package installers to set as default, the one you have just installed or the one built into the phone. Choose the one built into the phone, they will have different icons to identify them.
    If you don't get a choice to set as default continue with package installer you have just installed.
    Check if this helps.
