2
Parallel whatsapp problem
  1. Sasikumartm
    Gingerbread Jan 12, 2019
    Sasikumartm , Jan 12, 2019 :
    My parallel WhatsApp Messenger unable to load status ,DP and I am unable to share my photos through it ,In status error message coming unable to download and photo sharing it shows camera failed and for DP change it says unable to load photo I am in latest pie stable update kindly anyone please give solution
    Ashishbhai001 and Gaurav910 like this.
  2. Gaurav910
    Gaurav910 , Jan 12, 2019 :
    I am also facing lots issues in my parallel app whatsapp . I have also reported this bug. I have received the reply that they have fixed this bug in 9.0.2 update . But i am still facing those issues after 9.0.2 update .
  3. Sasikumartm
    Gingerbread Jan 13, 2019
    Sasikumartm , Jan 13, 2019 :
    bro I think we two only facing this problem
    Gaurav910 likes this.
  4. Gaurav910
    Gaurav910 , Jan 13, 2019 :
    There are other posts also . People are facing this issue .
    Ashishbhai001 and Sasikumartm like this.
  5. Sasikumartm
    if u find solution please let me know
  6. Gaurav910
    Gingerbread Jan 14, 2019
    Gaurav910 , Jan 14, 2019 :
    I have tried everything but nothing is working for me .
    This is serious bug. Oneplus should fix is asap .
    Ashishbhai001 likes this.
  7. sonalnagare
    Donut Feb 13, 2019
  8. grownup
    Cupcake Feb 15, 2019
  9. Sasikumartm
    Gingerbread Feb 15, 2019
    Sasikumartm , Feb 15, 2019 :
    ya with parallel space I can able to download and share photos but it had ads it was totally annoying and it slows your phone
  10. Sasikumartm
    I already submitted bug report to OnePlus but it was about a month before hope they will fix this issue on next update
  11. AnkurMeher
  12. Gaurav910
    Gingerbread Feb 20, 2019
    Gaurav910 , Feb 20, 2019 :
    Hi,
    Had the same problem and here is what worked for me :
    using a file manager navigate to the following folder : storage/emulated
    here you should find a folder named '999' delete this folder and try sending or downloading media in your parallel whatsapp again, it should work, and the 999 folder should be recreated and the content readable again.
    I'm not sure but I think after reinstalling the folder becomes unreadable because it's an encrypted folder, and reinstalling and enabling parallel apps might use a different encryption key every time for a clean install...
    Hope it helps...
    Thanks @Herrkruger
  13. Sasikumartm
    Gingerbread Mar 6, 2019
    Sasikumartm , Mar 6, 2019 :
    Hi ,This problem solved for me after my new update 9.0.4 ,I completely deleted all my storage , Backup my files to my laptop and clean installed this new update ,it was completely smooth without bugs till now
    Those who don't want this please try yowhatsapp this app had many features other than WhatsApp u get notifications of your friends if they come online with inbuilt status saver etc
  14. lvivero
    Donut Mar 27, 2019
    lvivero , Mar 27, 2019 :
    Same problem here. I've tried that and not working...
  15. realshivam07
    Froyo Mar 28, 2019
  16. KluGe
    Lollipop Jul 8, 2021
    KluGe , Jul 8, 2021 :
    Did you see that you answered a post that is two and a half years old?
  17. Waveform Modifier
    Marshmallow Jul 8, 2021
    Waveform Modifier , Jul 8, 2021 :
    With a spam link no less
    McJader likes this.
  18. tweetugowtham
    Cupcake Jul 22, 2021
    tweetugowtham , via OnePlus Nord , Jul 22, 2021 :
    Hlo I also occurs with these same problem...
    Really makes me tension...we cannot even share 2 or more images or files at a time...and also our cannot be seemed in the parallel wp (in status page and our media space)...please recover this proplem asap🙏🏻🙏🏻
  19. Waveform Modifier
    Marshmallow Jul 22, 2021
    Waveform Modifier , Jul 22, 2021 :
    Wrong forum
    flymaus likes this.
  20. tweetugowtham
