22
ROM Paranoid Android 6.0.1 - AOSPA - OnePlus 2
  1. davidrdgzlopez
    Cupcake Jun 24, 2016
    davidrdgzlopez , Jun 24, 2016 :
    The one I've found is one uploaded by you but it's the previous hydrogen camera version not the oxygen 3.0 version..
    jansvanda likes this.
  2. jansvanda
    Honeycomb Jun 24, 2016
    davidrdgzlopez likes this.
  3. kshitij1
    Donut Jun 25, 2016
    kshitij1 , Jun 25, 2016 :
    Hey @Arz Bhatia i used pa6.0.1 for a couple of days but the i flashed back to oos3.0.2. everything was going fine with me on aospa....but the app opening was slower,even the games loaded slow and lagged more than any other rom, the antutu score was always around 60k whils on oos 3.0.2 i get more than 85k,the fingerprint scanner was a tad bit slower,and the colours were dull,the whites were more yellowish,..all the comparisons in this draft are made with oos3.0.2.
  4. kshitij1
    Donut Jun 25, 2016
    Let me summarize all that i have written in one line,on aospa 6.0.1 my phone performs as if its on power saving mode on oos 3.0.2
  5. michaelliao07
    Gingerbread Jun 28, 2016
    HaRiHalus likes this.
  6. Hj.smits
    Eclair Jun 30, 2016
    Hj.smits , Jun 30, 2016 :
    How do I change the icon size? For some reason it changed from 4 in a row to 5 and I don't like it.
  7. muhsoh
    Gingerbread Jul 2, 2016
    muhsoh , Jul 2, 2016 :
    PA has gone mad on my OPT. Battery stats are showing crazy figures. Any idea why this is happening?
  8. Hj.smits
    Eclair Jul 3, 2016
  9. Hj.smits
    Eclair Jul 3, 2016
    Hj.smits , Jul 3, 2016 :
    The microphone isn't working for certain apps, like Whatsapp, Google voice and guitar tuner. It says in the app permissions they're allowed to use it, just they won't work since installing PA. Any tips? I've rebooted the phone, reinstalled the apps that don't work and turned the permissions off and on with no success.
    Edit/ fixed! Cortana's ''hey Cortana'' feature was hogging the mic, so I told her to stay away
    That's mad! Maybe clear cache for google play services?
  10. andreaparaggio
    Cupcake Jul 4, 2016
    andreaparaggio , Jul 4, 2016 :
    Hi people, what about an error while flashing the official signed rom? (http://get.aospa.co/official/oneplus2)
    I've oneplus 2 from cm13 rom, with twrp and supersu already onboard:
    This package is for "OnePlus2" devices; this is a ""
    Updater process ended with ERROR: 7
    Error installing zip file 'sdcard/storage/...'
    I've googled this error but i haven't found something related.. Is it a known issue?
    tnx in advance
    ap
  11. droid.
    Ice Cream Sandwich Jul 4, 2016
    droid. , Jul 4, 2016 :
    That's because you're on old firmware. Follow the instructions here.
    Jitesh Saitawadekar likes this.
  12. hovablack
    Cupcake Jul 5, 2016
    hovablack , Jul 5, 2016 :
    I had the same issue, think one sim has to be on GSM, so if the 1st SIM is on LTE change it to GSM first then you should be able to change the 2nd SIM, thats how it worked for me. GL.
  13. Lancelot_69
    Lollipop Jul 5, 2016
    Lancelot_69 , Jul 5, 2016 :
    Happening to me on occasion I just reboot and correct stats come up
  14. michaelliao07
    Gingerbread Jul 8, 2016
    michaelliao07 , Jul 8, 2016 :
    Basically I want to use both the sims on 4G simultaneously as in OOS.
  15. michaelliao07
    It just needs to complete a full battery cycle....then it returns to normal
  16. michaelliao07
    thats a bug I guess.....happened to me abt 4 to 5 times.....keeps changing
  17. Vishnugops
    Froyo Jul 16, 2016
    Vishnugops , Jul 16, 2016 :
    just reboot it, it will show proper stats
  18. nikhilendrapratap
    Gingerbread Jul 17, 2016
  19. mattmcg18
    Eclair Jul 17, 2016
    mattmcg18 , Jul 17, 2016 :
    What battery life you getting?
  20. nikhilendrapratap
    nikhilendrapratap , Jul 17, 2016 :
    Battery life is about 3.5 SOT but charing is very fast...
