7
Parking Location Saved Issues
  1. Cowslappa
    Eclair Oct 14, 2019
    Cowslappa , Oct 14, 2019 :
    Alright so I've been seeing a banner across the bottom of my screen saying "parking location saved" even though I am not using the parking location service on the dashboard. Does anyone know where I can find the app in the phone so I can change the location settings in it? I am running OxygenOS 10.0.1 and I have done a quick search for thus issue and found nothing so any little bit helps, thank you.
  2. G_Adam_Berkes_Kppp
    Cupcake Oct 22, 2019
    G_Adam_Berkes_Kppp , Oct 22, 2019 :
    Same issue for me, latest Oxygen OS update, OnePlus 7 pro. It keeps updating the parking location on main screen navigation.
    Mukarramas likes this.
  3. nareshsbn
    Cupcake Oct 23, 2019
    nareshsbn , via OnePlus 7 , Oct 23, 2019 :
    I am also getting same issue. couldn't figure out from where that message is coming. I have uninstalled all travel related apps. still I am getting that message. is it related to OS or location services? can someone give solution!
  4. TheLook
    TheLook , Oct 23, 2019 :
    I'm getting the same issue as well. It usually happens when I get home after unplugging the phone from the car charger which deactivates maps via Android Auto. It has been happening since the Oxygen 10 update.
    Nice to know it's not an isolated incident. Although, a shame it's happening at all. Hopefully this can be fixed soon.
    Thanks 1+
  5. somestars
    Cupcake Oct 27, 2019
  6. G_Manish_Kumar_KBpk
    Cupcake Nov 2, 2019
  7. roryrudy
    Gingerbread Nov 3, 2019
  8. joseph_moganti
    Cupcake Nov 3, 2019
    joseph_moganti , Nov 3, 2019 :
    Could be bloatware. Redmorph max app can help you turn off lot of unwanted OEM/system apps. Go to Data tab - settings on top right corner takes you to system apps. Try that.
  9. V1572558779020
    Cupcake Nov 8, 2019
    V1572558779020 , via OnePlus 7T , Nov 8, 2019 :
    I too am having this issue fresh outta the box as of 11/7. I just disabled the Parking Location so we'll see.
    It will update at random times throughout the day for me.
  10. 4thfloorcaveman
    Cupcake Nov 21, 2019
    4thfloorcaveman , Nov 21, 2019 :
    7T pro.
    Odd, this started happening after I updated to 10.0.0.4
    It is accompanied by the "google services is using location" notification
  11. yamarocket630
    Cupcake Nov 25, 2019
    yamarocket630 , Nov 25, 2019 :
    7pro - Also having the same issue with 10.0.2. I've just disabled the feature until I need it, that banner is pretty annoying.
  12. malilo_09
    Cupcake Dec 7, 2019
    malilo_09 , Dec 7, 2019 :
    I have the same issue with my new 7 pro... 10.0.2
    Just pops up randomly, i disabled the parking location feature. Also using Android Auto.
  13. GabrielAK
    Donut Dec 10, 2019
  14. #14
  15. DavidCampbell
    Eclair Dec 30, 2019
    DavidCampbell , Dec 30, 2019 :
    Having the same experience, popup every time i wake my screen and unlock. I also get a notification simultaneously saying I have no network even though the network works fine..
    Does anyone know anything about this?
  16. osyacoub
    Cupcake Jan 2, 2020
    osyacoub , via OnePlus 6T , Jan 2, 2020 :
    Same issue for me. Oxygen OS 10.3.0. It seems to show up when I press the Home button. However, I do have the Parking Location Service enabled in My Shelf, but I wouldn't expect it to save my parking location at any random time! It should save the parking location only when I ask it to.
  17. Q1574713378370
    Cupcake Jan 7, 2020
  18. David Marr
    Cupcake Jan 10, 2020
    David Marr , Jan 10, 2020 :
    Same issue for me on 7t Pro. I've disabled the widget but still get the banner when I go back to the home screen.
  19. U1577282536225
  20. Quetglas
    Cupcake Jan 14, 2020
    Quetglas , via OnePlus 7 Pro , Jan 14, 2020 :
    If you have a smartwatch that uses Bluetooth, the widget is recording a new parking position every now and then. it doesn't distinguish my Fitbit from my car 😯. Even worst, it deleted my tram recorded position and records a false new one, making the widget useless for me. Can you go back to the manual setting? Then it worked.
