7
Battery/Charging Pathetic battery drain
  1. prasanth6190
    Froyo Jan 10, 2017
    prasanth6190 , Jan 10, 2017 :
    I had brought oneplus 3T new phone last week. it was super awesome for first 5 days and ever since I gave the latest update my battery has been draining very badly. well it feels very bad to see 3450 mAh battery get drained so quickly.
    why do oneplus give updates which are always problematic. please resolve the issue else pls provide refund for the phone.
    rrgeada, Glennc98, ryangomes and 4 others like this.
  2. nnvt
    Froyo Jan 10, 2017
    nnvt , Jan 10, 2017 :
    It's not the update it's the Facebook and messenger apps. uninstall them and problem solved
  3. adhish_np
    Honeycomb Jan 10, 2017
  4. dmroopesh
    Ice Cream Sandwich Jan 10, 2017
    dmroopesh , Jan 10, 2017 :
    Battery life is excellent here. Consistent 5-6 hours of sot with moderate usage daily.
    jr.pasheko likes this.
  5. bhanuabd
    Donut Jan 10, 2017
    bhanuabd , Jan 10, 2017 :
    uninstall Facebook and all messenger apps or use Greenify app in play store
  6. nobelium76
    KitKat Jan 10, 2017
    nobelium76 , Jan 10, 2017 :
    By any chance did you search or even look at the recent threads? There seems to be more than enough threads that address the issue ..just saying.
  7. G_Rory_Farwell_Clpa
    Eclair Jan 10, 2017
    G_Rory_Farwell_Clpa , Jan 10, 2017 :
    what if I want to have Facebook and messenger still. I'm on op3 btw
  8. PsykoZ
    Cupcake Jan 10, 2017
  9. nikhilvarma892
    nikhilvarma892 , Jan 10, 2017 :
    You can still access it. Just open it in the browser, sign-in into Facebook and Add it to Home screen.
    You will then see an icon on the home screen and you can also enable notifications.
    This way you will be able to use Facebook and also not loose your battery life.
    Hope this helps.
  10. grcmp
    grcmp , Jan 10, 2017 :
    Since 4.o1. Battery lasts 4hrs that's all. Phone overheats. All the posted tops tried and failed
    Michelle Tremblay and Devshruti like this.
  11. dikpal14
  12. rrathodfly
    Donut Jan 10, 2017
    rrathodfly , Jan 10, 2017 :
    Battery issue is genuine. Fb might not b the only reason. They also run updates. They have done it by now
  13. Mithunn77
    Donut Jan 10, 2017
  14. tduran
    Donut Jan 10, 2017
  15. iamumesh
    Eclair Jan 10, 2017
  16. Raj_Prince
    Froyo Jan 10, 2017
    Raj_Prince , Jan 10, 2017 :
    I got my mobile 2 days back. facing same issues like over heating n battery draining drastically!!
    Devshruti likes this.
  17. Bresciaf
    Froyo Jan 10, 2017
  18. F_Mohit_Jain_OlMA
  19. Kiran.a.joseph
    Jelly Bean Jan 10, 2017
    Kiran.a.joseph , Jan 10, 2017 :
    You can continue to use fb and fb messenger with the following settings
    -Switch off chat option in fb app
    -Disable notification access to fb and fb messenger in Settings => Notifications. You can see the updates when you open the app but will not appear on status bar
    -Enable aggressive doze mode and ensure that fb and fb messenger is blacklisted (Nougat feature)
    -Enable app auto-launch restriction and ensure that fb and fb messenger is blacklisted (Nougat feature)
    G_Rory_Farwell_Clpa likes this.
  20. Devshruti
    Devshruti , Jan 10, 2017 :
    Hi, I bought this phone 2 days back, running on 3.5.4 version battery is not running half also that to with all battery saving mode kindly
