Paytm TM Issue
  1. Vrushank nijaguna s Eclair Mar 13, 2018
    Vrushank nijaguna s, Mar 13, 2018 :
    after rooting my mobile wid magisk root I'm facing issue with the app which won't open.
    it takes 5 minutes to open. it keeps on crashing
    ( I have even hided my root from magisk hide)
    can I get any solution for this issue?
  2. Saurabh40629 Honeycomb Mar 13, 2018
  3. Suryaprakash108 Cupcake Mar 13, 2018
  4. Vrushank nijaguna s Eclair Mar 13, 2018
  5. G_Shyam_K_dWLG Donut Mar 13, 2018
  6. elanglois Lollipop Mar 13, 2018
    elanglois, Mar 13, 2018 :
    Try using the Core Only mode to see if it's a module having the issue.. Otherwise, post the relevant portion of your logcat to a pastebin and I can look at it.
    Drasm19 and Hydra Bob like this.
  7. Vrushank nijaguna s Eclair Mar 13, 2018
    tried that also. even if I unroot my phone then also the problem appears the same!
    how to take the logcat?
  8. elanglois Lollipop Mar 13, 2018
    Matlog from play store or "adb logcat" from a PC.
    Unrooting can make it worse since your bootloader is unlocked. Some security apps can be nasty. An uninstall and reinstall sometimes works
    Drasm19 likes this.
  9. Vrushank nijaguna s Eclair Mar 13, 2018
    yeah.but I tried reinstalling it . it didn't work
  10. elanglois Lollipop Mar 13, 2018
    Only the log will tell whats up
    ghostofcain, Drasm19 and Hydra Bob like this.
  11. Vrushank nijaguna s Eclair Mar 13, 2018
  12. elanglois Lollipop Mar 13, 2018
    Start it recording. Open the problem app, then wait for failure. Switch back to Matlog, close and save the log. You can look through the log yourself and see if there is anything suspicious. I won't be able to look at it awhile. I gotta finish up a website
    ghostofcain and Hydra Bob like this.
  13. Vrushank nijaguna s Eclair Mar 13, 2018
    yeah ok I'll try resolving it if I fail then I'll send you the log.
    give me solution when ever you are free
  14. Vrushank nijaguna s Eclair Mar 13, 2018
    yeah this one worked but there are 2 apps now on my home. the one which I have rounded is working which looks like a parallel app and regular one is the same which crashes.
    how to remove that or make that one work?
  15. elanglois Lollipop Mar 13, 2018
    Turn off that parallel app crap, no wonder you have problems. Delete BOTH of them and reinstall
  16. Srikar21 Froyo Mar 13, 2018
    Srikar21, Mar 13, 2018 :
    i lol'd
  17. Vrushank nijaguna s Eclair Mar 14, 2018
    Vrushank nijaguna s, Mar 14, 2018 :
    I don't even parallel app option for Paytm. between I converted Paytm onto system
    after doing that it's working
    but that app which looks like parallel app
    that one is working and not the regular one
  18. G_Shyam_K_dWLG Donut Mar 14, 2018
    G_Shyam_K_dWLG, Mar 14, 2018 :
    reboot ur mobile after converting as system app...lets try that...
  19. Vrushank nijaguna s Eclair Mar 14, 2018
    did that first. no change
  20. Praty_28 Jelly Bean Mar 14, 2018
    Praty_28, Mar 14, 2018 :
    I had this same issue. Clearing cache from recovery fixed it for me. I dont know how this is related but it worked for me. Just clear cache and dalvic cache from twrp.
