44
PC specs
  1. dsmonteiro
    Community Consultant Staff Member Mar 3, 2017
    dsmonteiro , Mar 3, 2017 :
    Don't really know the used market. But I'd say no more than $500 / 500€.
    (It's worth more, though)
    Tokolozi, pa5t1s and sfomin like this.
  2. sfomin
    Nougat Mar 3, 2017
    sfomin , Mar 3, 2017 :
    ahh. not too far off what i paid for it...
    if i was to build it myself, it would be around $1100
    pa5t1s likes this.
  3. dsmonteiro
    Yes, I know, but you probably get the same gaming performance with current gen parts at around $700 (if you go for a lower CPU). A 1060 GTX or a RX 480 should outperform the 970 while costing less and you end up with a platform that you can't upgrade any further.
    But at around that price, I think it's a really nice purchase.
  4. sfomin
    Nougat Mar 3, 2017
    i do 0 gaming on the PC so its mostly for CAD and 3D printing. and so far it seems to work great!
  5. Mr. BG
    Marshmallow Mar 3, 2017
    sfomin and Tokolozi like this.
  6. dsmonteiro
    In that case, ignore what I said.
  7. Tokolozi
    Tokolozi , Mar 3, 2017 :
    Yeah the I7 makes sense for a cad build, i think be got a pretty good deal for that.
    sfomin likes this.
  8. sfomin
    Nougat Mar 3, 2017
    when i will be 80 years old, i might consider getting a mac [​IMG]
    toastytoast1234, Mr. BG and Tokolozi like this.
  9. dsmonteiro
    The new Ryzen might also be a great choice but still a lot uncertainty around it.
    Tokolozi and sfomin like this.
  10. Chris_S_96
    Cupcake Mar 3, 2017
    Tokolozi likes this.
  11. Tokolozi
    It looks promising, still needs a lot of game optimisations. And most likely the same for CAD software. Still a motherboard and cpu alone would have set him back about 350. And he would still need the rest around it.
    sfomin likes this.
  12. Mr. BG
    Mr. BG , Mar 3, 2017 :
    Because by then you may have saved up enough to buy one, and a decent car too, instead of that overrated Hitler car :p
  13. sfomin
    Nougat Mar 3, 2017
    exactly [​IMG] but i keep my hitler car though
  14. DRCH
    Marshmallow Moderator Mar 3, 2017
    DRCH , Mar 3, 2017 :
    Seen the Benchmarks? They seem pretty Solid especially if you consider the price
  15. geo07
    Ice Cream Sandwich Mar 4, 2017
    geo07 , Mar 4, 2017 :
    Customized HP Omen laptop , i7 7700, gtx1070, 16gb RAM, 256GB SSD and 2tb hdd 7200rpm, 4k screen. Not an Alienware but holds well so far.
  16. JorgeManuelSilva91
    JorgeManuelSilva91 , Mar 4, 2017 :
    Tower: Intel Pentium 4, NVIDIA GTS 250, 1 GiB RAM, 120 GB HDD;
    Netbook: Intel Atom, 2 GiB RAM, 160 GB HDD;
    Notebook: Intel i5, NVIDIA GT520M, 8 GiB RAM, 320+750 GB HDDs.
  17. dsmonteiro
    Community Consultant Staff Member Mar 13, 2017
    dsmonteiro , Mar 13, 2017 :
    Small update on my build:
    Final Specs
    • Core i7 6700k w/ Noctua NH-U12S cooler (TIM: Noctua NT-H1)
    • 2 x 8GB HyperX Fury DDR4 2133MHz CL14
    • Asus Z170 Pro Gaming
    • Gigabyte 1060 Gaming G1
    • 256GB Crucial MX100 SSD
    • 2TB WD Blue
    • Sound Blaster Z
    • Corsair RMx 650
    • NZXT S340 Black/Red with 2 x Noctua NF-A14 PWM on the front (filtered intake)
    Accessories:
    • Razer Blackwidow Chroma Stealth
    • Corsair m65 RGB
    • OnePlus Never Settle Mouse Pad (the smaller one)
    • Audio-Technica M40X
    Finally dedicated some time overclocking both the CPU and GPU.
    CPU is currently running at 4.5GHz@1.31V. Still deciding if I'll go for 4.6GHz since I'm still well under the 1.4V recommended threshold.
    GPU is set for +100MHz on the CPU and +400MHz on the RAM, with +11% power limit. Still need to stress test the GPU but it seems to hover around 2075MHz under full load (it adapts automatically).
    Tokolozi and Tobikage like this.
  18. Tobikage
    Nougat Mar 13, 2017
    Tobikage , Mar 13, 2017 :
    "Upgrade" the cooler by replacing the brown fans ?? :rolleyes:
    Tokolozi and dsmonteiro like this.
  19. toastytoast1234
    Marshmallow Mar 13, 2017
  20. Tobikage
    Nougat Mar 13, 2017
    Noctua = Brown colored fans.
    *Except for the ones they gave away with the Ryzen Review Samples
