51
PC specs
  1. Tobikage
    Nougat Dec 30, 2020
    Tobikage , Dec 30, 2020 :
    Fanghost ! :rolleyes:
    BeingIncog and Aditya Javadekar like this.
  2. Tobikage
    Nougat Dec 30, 2020
    It is expensive....sometimes unnecessarily impractical and frustrating in a lot of ways :p
    MicroATX all the way unless you need all those or more than 1x16 PCIe slots.
    You get only one of those Gen4 and one M.2 Gen 4 I think.
    Edit : I've gone from a 2700x and a 1070 to a 2200G btw.
    Tokolozi likes this.
  3. dsmonteiro
    Community Consultant Staff Member Dec 30, 2020
    dsmonteiro , Dec 30, 2020 :
    Didn't really see a reason to go with mATX. My case is ATX and I would just get a more cramped system with hotter and less capable VRMs.
    You downgraded your system?
    Tokolozi and Tobikage like this.
  4. Tobikage
    Nougat Dec 30, 2020
    Don't really use it much.
    OC'd the CPU and GPU on the 2200G and running 32GB of 3200MHz RAM so it's plenty for my weekend casual gaming.
    Using the stock heatsink from my old Phenom II 1090T.
    Temps stay close to 60C
    Will get a Zen 3 APU whenever they arrive.
    dsmonteiro and Tokolozi like this.
  5. Tobikage
    Nougat Dec 30, 2020
    Didn't really 'downgrade' it, more like moved it to another room and off my table. :sweatsmile:
    Tokolozi and dsmonteiro like this.
  6. dsmonteiro
    To be perfectly honest, I had quite the bias against them as well, thinking of them as a cheap brand. But I now realized they are very well-regarded for Ryzen AM4 platform.
    I was considering Asus Strix B550-F Gaming and Gigabyte B550 Aorus Pro. Then, I even looked at some of the lower end X570 that are somewhat in the same price range. The big problem is that all X570 at that price point end up being worse than a B550, you gain very little from the bumped up chipset.
    But then I stumbled upon the ASrock motherboard that is actually considerably more feature-rich than the former two.
  7. Tokolozi
    Most Original Avatar Dec 30, 2020
    Tokolozi , Dec 30, 2020 :
    Yes, ASRock had some biased views from a lot of people back then. But they have been proving a good option for many uses at their price point. Built a few pc's with friends for them, didn't have anyone complain about it yet....
    Tobikage likes this.
  8. dsmonteiro
    Tobikage and Tokolozi like this.
  9. Tokolozi
    Aditya Javadekar and Tobikage like this.
  10. dsmonteiro
    And a cooler.
    And a PSU.
    At least I skipped the Gen.4 NVMe. For now.
  11. Tokolozi
    I'll wait for the notification tomorrow :)
    What cooler and case tho?
  12. dsmonteiro
  13. Tokolozi
  14. dsmonteiro
    I know, I'm savage. Also brown fans. And no RGB.
  15. Tokolozi
    I wouldn't be able to, I tip my hat off to you brave brown one!
    No RGB I understand.... But brown.... I'm sorry need to take a stand there. That's why I went BeQuiet! Back in the day instead.
  16. dsmonteiro
    I did consider the Dark Rock 4 Pro. But it didn't fit my brown case fans :D
  17. Tokolozi
    But.... Noctua makes black ones now too :(
  18. Tobikage
    Nougat Dec 31, 2020
  19. dsmonteiro
    Community Consultant Staff Member Jan 5, 2021
    dsmonteiro , Jan 5, 2021 :
    That one ended up being a bust. There was no delivery date for it.
    Just ordered the Corsair 4000D (with a separate Airflow panel ordered to be delivered whenever there's stock).
    McJader, Tobikage and Tokolozi like this.
  20. dsmonteiro
    Was not willing to pay a 20€ premium for black paint.
