49
PC specs
  1. gaster
    Lollipop Moderator Jan 10, 2021
    gaster , Jan 10, 2021 :
    Finally it's ready guys. I got the thermal paste yesterday as well in the last minute so today the PC is finally completed.
    And a video here.
  2. dsmonteiro
    Community Consultant Staff Member Jan 12, 2021
    ayemei, Tokolozi, gaster and 3 others like this.
  3. sfomin
    Nougat Jan 12, 2021
    sfomin , Jan 12, 2021 :
    ooo, i have the same case. i must have a good computer then :rolleyes:
    can that thing run LSDyna?
  4. dsmonteiro
    dsmonteiro , Jan 12, 2021 :
    It's the inside that counts.
    You have the 4000D?
    Tokolozi, Tobikage and sfomin like this.
  5. sfomin
    Nougat Jan 12, 2021
    mine case looks exactly like what you posted, minus the red filler/handle. mine is black there. i need to build a new one that can handle my LSDyna stuff. At work, i run it on HPC but hoping i have something at home thats capable but doesnt cost me an arm and a leg.
  6. BeingIncog
    Nougat Jan 12, 2021
    Tokolozi and Tobikage like this.
  7. BeingIncog
    Nougat Jan 12, 2021
    Tokolozi, Tobikage and gaster like this.
  8. dsmonteiro
    Oh, that's the old one. I know have the Corsair 4000D. More photos when the system is ready to boot (still missing PSU).
    Best fans on the market.
  9. gaster
    Lollipop Moderator Jan 13, 2021
    gaster , Jan 13, 2021 :
    Yay!
    I have no clue :D
    Glad you like it buddy. Thank you!
  10. Tobikage
    Nougat Jan 13, 2021
    Tobikage , Jan 13, 2021 :
    Last stable release was in 2015 ? o_O
    It's either gonna run awesome or completely like shit because it cant use the newer hardware.
    Tokolozi, sfomin and gaster like this.
  11. sfomin
    Nougat Jan 13, 2021
    sfomin , Jan 13, 2021 :
    wont know until i run it then?
    Tokolozi likes this.
  12. Tobikage
    Nougat Jan 13, 2021
    Can check how much your current hardware is being utilised by running your usual workload.
    How many threads are being used , How much GPU / Cuda acceleration if any is being used.
    There's not much I could find in terms of requirements mentioned anywhere.
    Tokolozi and sfomin like this.
  13. sfomin
    Nougat Jan 13, 2021
    let me know if anything here is useful/telling:
    #PBS -l select=1:ncpus=20:mpiprocs=20:mem=110gb
    #PBS -l walltime=200:00:00
    #PBS -l tokens=20
    cores per compute node = 20
    Tobikage likes this.
  14. Tobikage
    Nougat Jan 13, 2021
    What's your current system specs ??
    The fact that they have a 32bit and a 64but version that specifies Single and Double for the CPU , I'd assume this will work on anything.
    Newer hardware will crunch through faster but you won't benefit from a huge number of cores I think.
    But you sure can multitask better.
    sfomin likes this.
  15. sfomin
    Nougat Jan 13, 2021
    Well i run my LSDyna simulations on HPC at work. It takes about 20 hours to run a full seat crash simulation.
    At home:
    Asus Z97-A MB
    i7-4790K CPU @ 4.00 GHz
    16GB RAM
    GeForce GTX 970 4Gb Video Card
  16. Tobikage
    Nougat Jan 13, 2021
    IMO , you're at that point where you've got the most out of your hardware if you bought it new or at the time it was released....so... it's the perfect time to upgrade. ;)
    Nvidia is recommended for Ansys....coz it can use CUDA acceleration. Quadros are recommended Doesn't say anywhere Geforce shouldn't work.
    Ansys can definitely use the newer hardware and larger core counts better whenever you move to a newer software down the line.
    https://www.ansys.com/about-ansys/partner-ecosystem/hardware-partners/amd
    High core counts should give you a lot more multi tasking flexibility.
    Also....Ansys was "optimised" for Intel in the past so shit like this happens even in 2020.
    https://arstechnica.com/civis/viewtopic.php?f=8&t=1468390
    So....Ryzen 5000 + a Quadro if you can get one at a somewhat reasonable price even if it's last gen is what I'd go for or something RTX 2000 series.
  17. sfomin
    Nougat Jan 13, 2021
    sounds like i need to do a lot of reading if i decide to build something for my FEA use. Thanks for the tips :cool:
  18. Tobikage
    Nougat Jan 13, 2021
    Starting with the licensing terms assuming you're legally getting one. :D
    Pricing / licensing tiers depending on how many cores you're allowed to use still exist. :rolleyes:
  19. dsmonteiro
    Community Consultant Staff Member Jan 18, 2021 at 6:52 PM
    dsmonteiro , Jan 18, 2021 at 6:52 PM :
    I think you jinxed it.
    S.M.A.R.T. is saying the disk is about to die so I removed it from the system, I am replacing it with a Sabrent Rocket 1TB (gen4) next week. Which means my next post is my final build.
    gaster and Tokolozi like this.
  20. dsmonteiro
    Community Consultant Staff Member Jan 18, 2021 at 7:02 PM
    dsmonteiro , Jan 18, 2021 at 7:02 PM :
    (NEARLY) FINAL BUILD
    Specs:
    • CPU: AMD Ryzen 5600X
    • Cooler: Noctua NH-D15S
    • Motherboard: ASRock B550 Extreme4
    • RAM: 2 x 16GB 3600 MHz CL16
    • GPU: MSI RTX 3070 Gaming X Trio
    • PSU: Fractal Design ION+ 860W
    • Storage:
      • Sabrent Rocket Gen.4 1TB NVMe (being added next week, for now it's still the 250GB Samsung 970 Pro)
      • Crucial MX500 2TB SSD
    • Case: Corsair 4000D (to be updated with an Airflow front panel)
    • Fans: 2 x 140mm Noctua fans on the front, 1 x 120 mm on the back
    gaster, McJader and Tokolozi like this.
