51
PC specs
  1. Tobikage
    Nougat Mar 9, 2021
    Tobikage , Mar 9, 2021 :
    Build a what now ? Another PC already ?
    McJader and Tokolozi like this.
  2. Tokolozi
    Most Original Avatar Mar 9, 2021
    dsmonteiro, Tobikage and McJader like this.
  3. dsmonteiro
    Community Consultant Staff Member Mar 9, 2021
    Tokolozi and McJader like this.
  4. .Deleted_Member.
    Nougat Mar 9, 2021
    .Deleted_Member. , Mar 9, 2021 :
    Me none, only cheap logi keyboards till now. Want to try mechanical kb.
  5. dsmonteiro
    dsmonteiro , Mar 9, 2021 :
    There are fairly inexpensive mechanical keyboards, even with Cherry MX switches. You have even cheaper alternatives if you're willing to go with clones.
  6. Tobikage
    Nougat Mar 9, 2021
    Ahem....
    BeingIncog, Tokolozi and McJader like this.
  7. Tokolozi
    Tokolozi , Mar 9, 2021 :
    MX-Blue
    MX-Green (fav so far)
    MX-red
    MX-Brown
    The Razer ones (MX clones)
    some tactile alps as well.
    dsmonteiro likes this.
  8. dsmonteiro
  9. Yash Pratap Singh.
    KitKat Mar 9, 2021
    Yash Pratap Singh. , Mar 9, 2021 :
    *cries in a corner with chiclet keyboard*
    dsmonteiro, McJader and BeingIncog like this.
  10. Tokolozi
    Nah I just like tactile.... And have heavy fingers!
  11. dsmonteiro
    I have to say my curiosity has been piqued. I wonder if I should order some Gateron green switches.
  12. Tokolozi
    They're like MXblues but with heavier springs. To experiment you can just order a spring set as well with blue switches
    dsmonteiro and McJader like this.
  13. dsmonteiro
    Community Consultant Staff Member Mar 10, 2021
    dsmonteiro , Mar 10, 2021 :
    You can always buy something like this and try 130 different switches :D
    https://bit.ly/3cm9u3K
    Seriously though, I've read amazing things about the Holy Pandas and Zealious V2, but they are sooooo expensive.
    Tokolozi likes this.
  14. Tokolozi
    Most Original Avatar Mar 10, 2021
    Tokolozi , Mar 10, 2021 :
    Good tactility comes at a cost!
    dsmonteiro and Tobikage like this.
  15. Tokolozi
    Most Original Avatar Apr 10, 2021
    Tokolozi , Apr 10, 2021 :
    So my trusted Coolermaster MM520 died yesterday. Just doesn't track on anything. Tried different PC's and all, just seems dead. The rgb works fine though....
    Bought a Logitech g502 Hero instead now though. @dsmonteiro
  16. dsmonteiro
    Community Consultant Staff Member Apr 10, 2021
    dsmonteiro , Apr 10, 2021 :
    I'm using the MX Master 2S. While it's not "gaming", it serves all my purposes well (and I can easily swap between the desktop and the laptop).
  17. Tokolozi
    I basically just need at minimum 2 programmable buttons and something that's nice in the hand. The mm520 delivered that, but think a failed firmware update killed it.
    Went for the G502 now since it seems to have great reviews, adaptable weight, fits my hand and was on sale.
  18. Tokolozi
    The G502 arrived,
    It feels nice in the hand, loaded it with the weights to see first, might make lighter over time. Scroll wheel and build is amazing considering this is logitech!
  19. .Deleted_Member.
    Nougat Apr 10, 2021
    .Deleted_Member. , Apr 10, 2021 :
    know some mice small and for left handed? using logitech m325 wireless mice.
  20. Tokolozi
    Hey,
    Never really looked for any tbh, I have big and right handed hands. Probably best to look for ambidextrous mice.
    .Deleted_Member. likes this.
