7
Pelosi blue sandstone case review
  1. migman
    Honeycomb Oct 21, 2014
    migman , Oct 21, 2014 :
    Hi all i thought i'd put some photos up of the the infamous blue Pelosi case.
    Over in all its just a plastic case with blue flocking felt sprayed on it so not like the sandstone on the phone but a lot smother and velvet effect, its nice.... but it wont last long and has already has dirty marks on it from half a days use in the warehouse I work, and the power cut-out was not great as you can see and has the plastic still attached in one part that I had to cut off with a Stanley blade.
    For £6.38 it is not a bad buy, but waiting 21 days for it is, you also get a nice cheap plastic screen protector for it in-closed with the case.
    I can foresee the case looking worse for ware after a short period with the flocking coming off maybe the plastic cracking, and im not sure on the protection side of it. I will try to update on it as it goes
    I give it a overall 7/10 as it is cheap, but you will probably be replacing it after 3/5 months.
  2. gusuraman
    Community Veteran Oct 21, 2014
  3. SpadeFire91
  4. kmccann90
  5. go for.android13
    Jelly Bean Oct 21, 2014
  6. 0mnomnom
    0mnomnom , Oct 21, 2014 :
    Damn that IS a nice color... would love the next OPO to come in that color! :D
  7. peteryu
    KitKat Oct 21, 2014
    peteryu , Oct 21, 2014 :
    Thanks for the review!
  8. 4nlimited3dition
  9. migman
    It has a softer inside than outside with strands of fabric, i dont know if it will help or not. Im waiting on my second opo to be delivered so the wife will inherit this one, that should accelerate the test of the case with her track history!!
    8ioerwoiowirwe likes this.
  10. migman
    Honeycomb Oct 22, 2014
    migman , Oct 22, 2014 :
    Ok day 2 and the dirt is really starting to show on the edges of the phone now. So unless this is going to be used in a clean environment (unlike my grubby warehouse) I would only recommend it for Sunday best.
    It is possible to remove the case without any damage to phone or case if you are careful. So I think it's back to my Tudia red case for work as that has faired a lot better.
  11. frankykw
    Froyo Oct 24, 2014
    frankykw , Oct 24, 2014 :
    i just got a black one, some reviews are concerning about the durability of the sandy back. Hope Pelosi had it built with quality
  12. JasonOnTwoWheels
    Gingerbread Oct 24, 2014
  13. alexrua
    alexrua , Oct 24, 2014 :
    I got my pelosi black case about 2 days ago and its pretty good liking it so far :) If you want pictures just ask.
  14. shastada
    Ice Cream Sandwich Oct 24, 2014
  15. holgerhbaer
    Cupcake Oct 26, 2014
    holgerhbaer , Oct 26, 2014 :
    will there be a version that covers the entire frame? I don't like th huge cutouts on top and bottom
  16. sp99
    Community Veteran Oct 26, 2014
    sp99 , Oct 26, 2014 :
    Be careful! Mine has damaged the back of my opo! :mad:
    gusuraman likes this.
  17. Deactivated User
    Oct 26, 2014
  18. gusuraman
    gusuraman , Oct 26, 2014 :
    With hard cases it's impossible, unless you get those made in 2/3 pieces.
    See the GKK hard case in the list linked in my signature
  19. Pedro
    Ice Cream Sandwich Oct 26, 2014
  20. Hkphooey
    Honeycomb Oct 26, 2014
    Hkphooey , Oct 26, 2014 :
    Pop up some pics mate
